How often do you guys need to inflate your tires?
Discussion in 'Gen 3 Prius Main Forum' started by Roger T, Apr 13, 2014.
  1. Okinawa
    Okinawa Senior Member
    1,333
    320
    They should be inflated to the pressure recommended by Toyota. Mine is 35 front and 33 rear. Pressure should be checked once a month.
  2. fuzzy1
    10,406
    That jump wasn't just from tire pressure, or even mostly from tire pressure. Other things contributed, probably including driver behavior.
  3. MikeDee
    MikeDee Senior Member
    1,576
    596
    San Francisco Bay Area
    Is there a chart or study based on test data that shows improved mpg with higher inflation pressure? I hate the way my car rides and handles with overinflated tires. Just going from 42/40 to 38/37 gives me an improved ride with maybe a minor to no decrease in gas mileage. YMMV
