2006 blue Prius clear coat paint problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by scionfriar, May 15, 2014.
  1. scionfriar
    scionfriar Junior Member
    29
    For the past several months, I've been losing the clear coat (I believe) from the fro of of my Prius. It started small and kept spreading. Now most of the roof is gone and it's starting down the edges of the doors.
    Clear plastic continues to flake off and it appears that where it has the paint itself is fading.
    My Prius is parked outside in sunny California, so it's definitely been in a lot of sun, but I've taken good care of it. Has anyone else had a similar problem? Any fixes that don't involve a complete new paint job?
  2. JC91006
    JC91006 Senior Member
    16,928
    8,637
    are you the first owner? For an 8 year old car to look like that, it would have to have been repainted with a cheap clearcoat or you have it in the sun and rarely wash it.
  3. scionfriar
    29
    Yes, I'm the original owner. :(:(
    I didn't wash it weekly or anything but about every month.
  4. scionfriar
    29
    My coworker has a blue 2005 that is doing exactly the same thing. Bizarre.
  5. JC91006
    16,928
    8,637
    The dirt on the car eats away at the paint. In really hot weather (maybe you are in the hotter parts of CA), this will accelerate the paint destruction.
  6. scionfriar
    29
    We both live by the coast, so it's not ridiculously hot (except for the past few days)!
  7. JC91006
    16,928
    8,637
    oh, the salt water effect. that can't be good........
    I have a 2006 blue and I'm inland. No fading paint here.
  8. scionfriar
    29
    Well, relatively...Costa Mesa and Long Beach.
  9. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ...gee no sign of that on our 2006 whitey...just checked
  10. JC91006
    16,928
    8,637
    Honda used to have a problem with their dark blue paint on their Odyssey vans. They offered an extended warranty on the car and repainted most of them for the owners. Some paints/clear coats are just more problematic.
    Lucky for us, the blue paint on the Prius isn't that expensive to repaint....compared to a red Prius.
  11. scionfriar
    29
    Would you take it to the dealership for a repaint or a high quality paint shop?
  12. JC91006
    16,928
    8,637
    Personally I would just get it painted at a reputable paint shop. The dealer probably would do the same and charge you a high middle man fee.
    You have to remember this is a 2006 and you have to consider how many more years of service you would expect from the car. The same type of thinking would apply if you needed a replacement battery. A new battery would last 8 or more years but your car as a whole probably won't make it that far.
  13. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    I see that with the seaside blue a lot.
    Kestrel1 likes this.
  14. scionfriar
    29
    Thanks for the input! It's probably not worth it, but it's such a great car with less than 100,000 miles still.
  15. JC91006
    16,928
    8,637
    I would think only the roof, hood, and trunk area is like this. You can probably get only those areas painted at a reasonable price. No need to paint the sides of the car.
  16. TampaPrius.com
    461
    300
    Tampa, Florida
  17. scionfriar
    29
    I took it to a couple different paint shops and they both essentially said the same thing: it's not worth it. They pointed out how the peeling was starting at the top of the doors and that you'd really have to repaint the whole thing and to do a really good job would be more than it's worth.
    Since then, the clear coat on the roof is gone and the hood has some large bubbles on it already. Quite a bummer for such a great car.
  18. bisco
    52,745
    bizarre. how 'bout a cheap at earl scheib?
  19. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Vinyl wrap it
    DigitalNomad likes this.
  20. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    To do it right the old paint has to be stripped off. If it isn't it will continue to delaminate under the new paint. How much should be spent to restore a car with no collectible value?
    If an inexpensive paint job is going to be done then sell the car before the warranty expires. The new paint will start to blister and peel shortly thereafter.
    Paint isn't as durable as it used to be. The cars that I have seen with paint in that condition come with owners that didn't wash & wax.
