Cracked rear lens
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Jefreestyles, May 20, 2014.
  1. Jefreestyles
    Jefreestyles Junior Member
    all,
    I recently found this on my car.
    https://dl.dropboxusercontent.com/u/12007759/PriusC_CrackedLens.jpg
    The light is still working and the crack doesn't diminish or do anything to my light at all.
    I called the closest Toyota Service shop and they quoted parts and labor at $257.25 + tax.
    What should I do?
    Also, what could have caused this? Looks like a it was shot by a bb gun. I don't remember hearing it crack while driving. So it must have been parked already and then something/someone hit it.
  2. JC91006
    JC91006 Senior Member
    16,733
    8,548
    Most likely cause is debris from the road at highway speeds, it's not easy to hear those. You can tell the paint that chipped off as well, a BB gun probably won't do that.
    You can check for the parts on Ebay or at online Toyota dealerships. Prices are often better online. Just make sure you buy OEM so it would match the other side.
    Replacement shouldn't be that hard to DIY, should be just some bolts to remove on the light and possibly some clips inside the car.
    Jefreestyles likes this.
  3. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    I guess add a little more dough and get a nice pair of aftermarkets?
  4. JC91006
    16,733
    8,548
    This is all of personal preference. I prefer the fit and finish of the OEM stuff and it looks original. Some people like the more exotic aftermarket stuff, which also shows something has been replaced from OEM. When you decide to sell the car, the buyers may or may not like the aftermarket add on.
  5. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    about 130 shipped per tail oem toyota part from ebay. install takes 5 minutes and is easy
  6. mertechperformance
    532
    126
    Nor-caL
    A lot, NOT ALL folks keep the stock parts as well. or hold onto a car for SOOO long the loss of stock parts becomes a very moot point. Unfortunately these will never be collectible cult cars...
  7. -y0-
    -y0- Member
    142
    Pacific NW
    I have a set for sale if interested.
