P1121, P1116, Changed Coolant Valve, now Red Triangle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bryan D., May 23, 2014.
  1. Bryan D.
    Bryan D. New Member
    Hey guys,
    So I drive a 2008 and a couple months ago I started getting the Check Engine Light. Codes P1121 & P1116. Found out it was most likely related to a faulty Coolant Control Valve or Electric Water Pump. Since the pump was just recently changed I went ahead and got the valve changed.
    The light is still coming and going but now when I go on the expressway that red triangle with the exclamation pops on with a little beep. Only pops on for a couple seconds and keeps coming back until I drive a bit slower.
    Any idea what might be going on and how it might relate to the Coolant codes? I've read about draining the coolant fluid and about topping it off. Coolant looks full and I don't hear any air bubbles.
    Let me know what you think before I spend another fortune trying to figure it out at the mechanic!!
    Thanks!
    Bryan
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,832
    Clearwater, Florida
    That's not a check engine light that's the Master Warning Light. I wouldn't drive the car far until you pull the codes. The car ain't kidding when it throws that one.
    How did you change the valve? Did you duckbill off the hoses or drain the entire coolant?
    Where does the coolant look full? Overflow or rad? The overflow is meaningless you must take the plastic cover off and open the rad cap to check the real coolant level.
    If you drained the entire coolant it is very difficult to bleed the air. I'm pretty good at it and have a ulift and still struggled when I did mine. The trick is to power cycle on the CHRS thermos as you bleed as air tends to get trapped in the thermos and at the top of the engine. Patrick Wong had a cool get around by pulling the CHRS relay and paper clip jump out the relay 12 volts acorss it to force the thermos to cycle a few times. I missed that on my bleed and it made a bleed difficult.
    This car is weird about engine overheat also. Sometimes it throws the master light but no one every reports the true overheat icon which is the thermometer in red.
  4. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    This is a great tool for burping the coolant:
    Thanks to Patrick I ordered one of these and it is a huge time saver and coolant saver. It attaches directly to the radiator and holds about 2 pints so you can squeeze the coolant hoses and burp out the air. You can also jump the coolant pump relay and run the coolant pump.
  5. Bryan D.
    Bryan D. New Member
    Thanks for all the help guys. Well I went to a Toyota specialist and had the coolant fluid bled and refilled with Toyota coolant. Hopefully that solves that problem for the moment. Surely enough now the mechanic says I have a leaky engine water pump. Another few hundred to fix. Not sure how a seemingly small problem just keeps unearthing new things to replace..
  6. TampaPrius.com
    461
    300
    Tampa, Florida
    Most water pumps seep a small amount through the weep hole. Verify that it is actually leaking. This may be something that can be put off for a while. Keep an eye on the overflow tank and see if you are losing coolant. It may be hard to tell because depending on how well they bled your cooling system it may still burp a few air bubbles over the next week or so.
  7. Bryan D.
    Bryan D. New Member
    Great, I appreciate that info. I'll check that leak myself today. Hopefully it's a small one.
  8. universeisgr8
    universeisgr8 Junior Member
    Virginia
    its an old post but I am sharing my exact same experience and an easy fix. I had p1121, got coolant control valve changed by a friend who is also a mechanic. The car ran fine for a few days then when I went on the freeway, the red triangle started to go on and off intermittently. It also threw a new P1150 code.I had the doubt that it was coolant related because I saw the mechanic drain a lot off coolant which he said he had refilled.
    I always have a bluetooth OBD code reader connected to my car, so i fired up torque pro app and saw the coolant temp was 230F. I didn't know what should be the normal range at that time. Drove a bit slow and came home fine. Next morning, checked the radiator and sure enough i couldn't see coolant in it. Luckily, i had the coolant bottle laying around. Did some more online reading on how to bleed coolant with many suggestions most of which were overwhelming.
    Until now it was all the background. here is one of the easiest fixes you would find.
    First I opened the radiator bleed valve exactly three turns. This is located under the panel on the right side of the radiator and requires a hex key to loosen. Then opened the radiator cap, turned the engine on and set the fan at high speed and in the heat setting. Then slowly started filling coolant in the radiator. It took about 1.25 Liters and finally i started to see the coolant level coming close to full. Then I went inside the care, and slammed the accelerator in the idle position, went back and saw coolant level dropped again, topped it up again. I also saw that increasing the RPM cranked the pump and there was a little coolant that started to come out of the release valve, which was a good thing and confirmed that there was no more air. Finally, replaced the radiator cap and done.
    Overall it took 15 mins to do all this. Ran the car again on freeway and coolant temp was steady at 85F, and no triangle or any other error. I dont know why people suggest to short start the water pump, or connect a hose and bring it back to the reservoir and what not. Its all daunting info floating around. For DIY, i found it sooo much simpler than i thought.
  9. mr_guy_mann
    mr_guy_mann Senior Member
    4,015
    1,947
    NJ-USA
    The "hose to the reservoir" is usually referenced for bleeding the inverter cooling system after changing the electric inverter pump.
    Good job on taking care of the engine cooling system (really that should have been done properly by your mechanic).
    Might want to recheck the system level in a day or so - when it's cold.
  10. garagekoalas
    garagekoalas New Member
    Santa Rosa
    I agree so many of these posts are overwhelming. Thanks so much for this reply, I may try this.
