OEM fog light help!!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by WNY-HYBRID, Apr 29, 2014.
  1. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    I have a 08. Bought a oem fog light kit. Does anyone have any install instruction for this? The kit came with nothing but a switch, wiring, bulbs and trim pieces.. No instructions we're given. I searched and can't find anything.
  2. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    Finished today. Bought complete kit from ebay for 54.95. Complete with oem style switch, wiring and trim bezels. If you need help on the install message me
    oasis likes this.
  3. sambojoho
    sambojoho Proud conservative
    92
    Ohio
    Congrats, that looks great!
    iPhone ?
  4. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    Thank you sir. I'm definitely happy with it. Upgrading my headlights to HIDs. Contemplating the fogs too.. :)
  5. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Do your fellow drivers a big favor, and don't install HIDs in you
    your reflector based foglights. They'll blind everyone with glare because they don't have proper cutoffs like projector lights.
    SCH-I535
    DGH likes this.
  6. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    Ok, it was just going to be for looks anyways. I'll save the 100.00.
    I saw the hid projector retrofit thread.. Heating up in the oven, ect.. If I put HIDs in my halogen fixtures, will that produce a decent end result? Is the projector setup worth the time and risk damaging the headlights?
  7. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    Where did you run the wire into the cabin for the switch?
  8. xliderider
    8,140
    3,276
    Honolulu, HI
    It's in the instructions. There is a rubber grommet near the brake pedal.
  9. TampaPrius.com
    461
    300
    Tampa, Florida
    Thanks, the kit doesn't come with instructions.
  10. xliderider
    8,140
    3,276
    Honolulu, HI
    There is a link in the first post or thereabouts, of the stickied thread (oem foglights available), to a pdf file download of the instructions.
    Whoops, just noticed this is in the gen2 forums. :p
    TampaPrius, perhaps you can take up the OP's offer to help by private messaging him. ;)
    #10 xliderider, Jun 11, 2014
  11. okiektm
    okiektm Junior Member
    Oklahoma City, Oklahoma
    Hi Wny
    Where did you find the instructions for the install of the OEM Fog lights. I also bought a set and it didn't come with the instructions.
    Thanks
    Okie
  12. xliderider
    8,140
    3,276
    Honolulu, HI
  13. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    Wiring is a bit different on the 2nd gen.
    I'm not sure where to pull 12v under the hood. Is it a bad idea to use the jump terminal?
    iPhone ?
  14. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    you can get 12 from the big terminal in the fuse box on the driver's side under the hood. but then you'd need to be careful not to leave your fogs on all night and kill the battery. might be a switched terminal in the fuse box too.
