Traction Battery Survey.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by uart, May 31, 2014.
  1. I came to these forums specifically because of a traction battery related problem.
    12 vote(s)
    12.2%
  2. I came to these forums for any other reason and have since had a traction battery failure.
    18 vote(s)
    18.4%
  3. My gen2 prius has had no battery failure to date.
    68 vote(s)
    69.4%
  1. uart
    uart Senior Member
    4,220
    1,209
    Australia
    - Please report the status of your gen2 prius traction (high voltage) battery.
    - Please participate whether or not have had a failure.
    - Please only select the first option if you came to these forums specifically because of a problem that turned out to be HV battery related.
    I've kept the options as simple as possible, so as to obtain only the most basic aggregate data of approximate percentage failures.
    It would also be very useful if posters reporting a failure could also post a brief reply reporting the approximate age and mileage at the time of failure, along with (if possible) the geographical region where their Prius was mostly driven.
    For example something like this: 2004 Prius. Battery failed in 2012 at 118k miles. Location: Southern Ca.
    Thanks for participating. :)
    wjtracy and Dylan Doxey like this.
  2. Priusyipee
    Priusyipee Active Member
    354
    269
    Upstate New York
    2005 Prius - 206,500mi. = ALL IS WELL!
    KhaPhoRa likes this.
  3. saraheschwartz
    saraheschwartz New Member
  4. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    No failure yet on my '04 GEN-II traction battery. It is driven daily and has 115,000 miles on it. Bought it new just before the '05's came out.
  5. Former Member 68813
    3,524
    983
    US
    where is the option for
    I came to these forums specifically because no traction battery related problem.
    You need that for completeness.;)
  6. Merkey
    Merkey Active Member
    300
    275
    Birmingham, Michigan
    2006, 186K, so far so good.
  7. KhaPhoRa
    KhaPhoRa Member
    168
    37
    2006 150,000 miles, all signs point to good traction battery
  8. JC91006
    JC91006 Senior Member
    16,660
    8,509
    All original HV battery
    2005 - 155k
    2006 - 127k
    2008 - 130k
  9. mikemar
    mikemar Junior Member
    Mass
    2005 258,000 miles all good
  10. cloud4310
    cloud4310 New Member
    Washington, District of Columbia
    Just replaced my HV battery - 2006 at 91,000 miles.
  11. JC91006
    16,660
    8,509
    Out of the hundreds and hundreds of visitors on PC each day, there should be more than the 25 people that have responded to this survey. Maybe there's a way to make this a pop up when people first go onto priuschat?
  12. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Yep I agree JC. I was just about to give this thread a bit of nudge myself. :)
    Come on people, please vote in this poll.
  13. bisco
    51,043
    threw one in for my daughters 08. do you want my neighbors 04?:p
  14. Former Member 68813
    3,524
    983
    US
    My experience with polls (on various forums) is most people don't like to bother to vote. Not sure if this is laziness or not.
  15. Kay-Kay
    Kay-Kay Junior Member
    40
    2005 Prius. Battery failed at 153k.
    "the geographical region where their Prius was mostly driven..."?
    - This would be a bit complicated as the car barely did an approx 1K distant trip to failure location which is, Nigeria. Documents however indicate previous locations as MD (2008-2012) & PA (2012/13). Hope that helps.... or Has it made the analysis more complicated?:rolleyes: lol.
  16. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Interesting, so it's failed very soon after you buying it second hand in Nigeria. Or did you move to Nigeria and have the Prius shipped it out there with you?
    There seem to be quite a lot of cases of people buying secondhand and having traction battery failures fairly soon afterwards. I wonder how many of these are due to the previous owner getting a battery problem and doing a quick and nasty fix before unloading it?
  17. JC91006
    16,660
    8,509
    I believe we will see more and more of these cases where people buy a high mileage Prius and have the battery fail soon after purchase. This is the common practice where people get rid of their problems and buy something newer. The biggest problem we have with the Prius is that it has the reputation to be bulletproof and many people that don't know the cars and assume they are bulletproof. They buy them with 200k+ miles and assume they will be troublefree for another 200k, just like all the taxi's they read about. I see lots of ads on craigslist of broken Prius cars, only to be sold and reappear a few days later at a higher price.....after a band-aid repair.
    After a car reaches 200k miles, any component can fail, not just the battery. This thinking seems to be known knowledge however people don't take this into consideration when they buy a Prius. That's what puzzles me.......
  18. Kay-Kay
    40
    Yea, you're right. It failed shortly after buying it second hand in Nigeria.
  19. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Still original HV battery; 2007 w/ 125,000 miles. Hope it dies while under CARB warranty.
  20. wjtracy
    wjtracy Senior Member
    11,359
    3,606
    Northern VA (NoVA)
    2006 doing good at 135000 miles (knock on wood)
