AC fuel use
Discussion in 'Prius c Fuel Economy' started by FlipFeel, Jun 9, 2014.
  1. FlipFeel
    FlipFeel New Member
    2014 Prius c
    I believe I get about ~6 mpg loss, just on a gut feeling. Has anybody ran their own numbers? I noticed the AC pulls ~1850 watts full power with torque, but I don't know how accurate that is.
    EDIT : ~1850 watts, not 1275 watts
    #1 FlipFeel, Jun 9, 2014
  2. hieronymous
    hieronymous Member
    154
    92
    Auckland, New Zealand
    2013 Prius Plug-in
    The A/C will pull a lot more than that - the A/C consumption power PID scale is up to 12750 watts. Depending on the ambient temperature, the climate air temperature setting can be raised until the A/C cycles between 250-300 watts and off; there is no observable effect on mpg at this level.
  3. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    My guess is more like 3-4 but it depends a lot on what temp you have it set AT, how hot it is outside, using recirc or not AND whether or not you have "econ" activated.
  4. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    I found pretty much the same thing on the regular Prius and the PIP (and now with my Volt too) the AC has minimal effect on mpg.
    Use it freely, and it's better to keep battery cool too...
  5. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    The 12,750 watts seems high. The Gen3 A/C is rated at 5000 watts.
  6. Easy Rider
    982
    210
    N. Central Florida
    I think there is a typo somewhere.
    12 KW is enough to power my whole house......with pretty much everything going full blast. :)
  7. Mendel Leisk
    42,289
    We've got a pretty regular run to downtown. It's been a while, but I can recall doing it with the A/C on, and noticing with the ScanGauge liters/100 km for that trip the number was staying stubbornly high (bad). Just seat-of-pant: without A/C we might be down to 4.2 (liters/100km), with A/C it was more like 4.5~4.6.
    Also, if it's shortish trips, and not crazy hot, I prefer to just leave the A/C off, roll down the windows, roll them back up halfway in the highway portions.
  8. hieronymous
    hieronymous Member
    154
    92
    2013 Prius Plug-in
    Agreed, but the NHP10 and ZVW30 spreadsheets both show 17.098 HP / 12750 Watts. Perhaps Vincent1449p will see this and comment...
  9. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    I followed the same min. & max. values in Repair Manual:
    It show the mathematical min. & max. values and the actual operating ranges are shown in the remarks column, i.e. 1 ~ 5000W.
    Vincent
  10. hieronymous
    hieronymous Member
    154
    92
    2013 Prius Plug-in
    Thanks for the clarification, VIncent!
    iPad ?
  11. Easy Rider
    982
    210
    N. Central Florida
    Am I missing something here ?
    How is that a clarification ?
    12,750 W is quite different than 5,000 W
  12. hieronymous
    hieronymous Member
    154
    92
    2013 Prius Plug-in
    Probably...
    It's a clarification for me.
    iPad ?
