Prius v: 300,000 miles club
Discussion in 'Prius v Main Forum' started by usbseawolf2000, Feb 7, 2014.
  1. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    I think he delivers medical supplies all over Florida.
    Josem3 likes this.
  2. Troy Heagy
    Troy Heagy Member
    1,218
    Oh..... sounds like the guy who had the 1.1 million mile Civic, who was also a delivery guy. Perhaps the Prius V will be the first million-mile prius.
  3. Tom Prodo
    Tom Prodo New Member
    2013 Prius v wagon
    If you got 300,000 miles out of any car, no matter what brand or model, you win. If it dies, get a new car and don't worry about the value of it. Are you hauling cargo cross-country in this Prius? How could you get 300,000 miles in 2 or 3 years?
  4. markabele
    5,084
    1,782
    Nebraska
    I'm curious about this, too. I don't think it's been answered yet.
  5. ewxlt66
    535
    186
    Dana Point, CA
    Actually I said what he does. I've heard he often logs 600 miles in a day.
  6. kammssss
    kammssss Member
    287
    86
    SoCal
    Ouch! Hope this car last you 6years. But I am pretty sure you make a lot of money with your job, so your decision should be pretty sound. Keep us posted.
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  8. ewxlt66
    535
    186
    Dana Point, CA
  9. 2 fas 4 u
    2 fas 4 u Active Member
    320
    353
    florida
  10. ewxlt66
    535
    186
    Dana Point, CA
    Wow!
  11. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    2 fas 4 u, could you attach a pic? ;)
  12. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    He takes the long way to work.
    WesleyG94 likes this.
  13. Troy Heagy
    Troy Heagy Member
    1,218
    And I thought my 200 miles/day was a lot. (Just this year.)
  14. GregP507
    GregP507 Senior Member
    3,002
    481
    I would like to know if only synthetic oil was used, and how much the maintenance has cost.
  15. ewxlt66
    535
    186
    Dana Point, CA
    If memory serves, all 2012 and up use synthetic every 10k.
    He's had no problems except a wheel bearing replacement.
  16. 2 fas 4 u
    320
    353
    florida
    Update 350000
    Problem go to start I here shaking in front. Goes away ok could be the infamous engine shake.
    arrive at pick up got to leave as engine kicks on starts rattle noise let off Gass goes away
    get gas as I drive off as engine comes on engine again starts shaking or it can sounds like it coming from electric side.
    only happens from ev to engine only if I sit for more than a minute. Doesn't happen after a start driving. As I am writing I've been sitting for about 10 min hold on let me try again. OK I'm leaving starts to shudder let off go again starts shuddering.
    doesn't happen even when I stop a light orlet off gas only after I sit for more than a minute very strange anyway off to repair shop.
  17. telmo744
    2,181
    769
    Portugal
    Time for a manifold/EGR clean up?
    It may have a vapour lock, or a check valve failure in the fuel rack...
    Let'em see what comes by...
  18. 2 fas 4 u
    320
    353
    florida
    Made it through the night 7:00 am last stop shudder happens threw a code on my wayto auto zone.
  19. GregP507
    3,002
    481
    I'd like to know if the valves are controlled electronically to reduce engine-shake on startup. Mine shakes rarely; most of the time I can't even tell when it starts or stops.
  20. 2 fas 4 u
    320
    353
    florida
    Getting p0301. an 302 dealer says I don't have 0w-20 in engine which causes a misfire. Need some help
