AC Vent Removal / Replacement 2010
Discussion in 'Gen 3 Prius Technical Discussion' started by hauchinango, Jun 17, 2014.
  1. hauchinango
    hauchinango New Member
    I
    I recently bought a certified Prius. All looks good so far, but one of the vents in the middle of the dash has the slider broken off, so I have to use a key or something to open or close the vent.
    Any idea how to remove this vent? I have the piece just need to glue it back on. Or, if I can remove it and order a new one, that would work.
    Thanks, more questions to come I am sure. I tried searching with no luck.
  2. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    I don't remember that last time I though that I needed to close one of the dash vents.........and that's been a LONG time.
    How about aiming it so that it doesn't blow right in the drivers or passengers face and just leave it open ??
    I think it is likely that you will find getting it apart is a LOT more trouble than it's worth.
    No harm in asking though; I might be totally wrong.
  3. neez
    neez Member
    194
    37
    How long ago did you buy this "certified" prius? They obviously didn't do a good job going over it. If it was only a few weeks ago, most dealerships would fix it for free.
  4. GregP507
    GregP507 Senior Member
    3,002
    481
  5. A617
    A617 Member
    213
    95
    OKC, OK
    Umm You have CPO why don't you sent it to the dealer to fix it!
  6. phoenixgreg
    phoenixgreg Senior member
    1,157
    294
    66
    Phoenix
    It's a really big deal to repair those vent sliders...the dash plate needs to come off in order to replace the vent vanes and controls. But if the car was Toyota-certified, you are justified in requesting replacement vent controls. Just be prepared to leave your car with the dealership for 2 to 3 days...it's not an easy job.
