Your Biggest Energy Pig at Home
Discussion in 'Environmental Discussion' started by hill, Jun 30, 2013.
  1. Okinawa
    Okinawa Senior Member
    1,333
    320
    Don't forget the view you have. That's priceless. If I lived closer to Maine I would spend a lot of time there.
  2. Mendel Leisk
    41,317
    ^ Hmm, I wouldn't want that. My last elec toothbrush (same brand but cheaper model, a gift from our grateful dentist for for my continuing generous support of his lifestyle, lol) expressly said to discharge it completely, once a year. This one had no instruction to that effect, as far as I can remember.
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I was reading about a high SEER device from Fujitsu and came across a forum discussing high phantom losses
    Disappointing phantom load on 27.2 SEER Fujitsu 9RLS2 minisplit | GreenBuildingAdvisor.com
    Hobbit adds his two cents here.
  4. hill
    8,794
    just snapped this shot from our master bedroom as I'm typing .... an open window on the water beats 82 degrees any day ;)
  5. Okinawa
    1,333
    320
    Montana is a beautiful place as well. Sure beats where I live, a Chicago suburb.
  6. walter Lee
    1,126
    376
    Maryland
    I've got a 1500 sq ft all electric middle 3 level town home : The biggest electric usage is my 2 ton Heat Pump (HVAC) which normally uses more electricity to heat in the winter than cool in the winter. My baseline usage for lights, hot water, refrigeration, cooking , electronics, and distribution charge is about 200kwh/month without much heating or cooling. Heating adds as much as 900 kwh /month while Cooling adds as much as 250 kwh /month. Last time I calculated - I use about 5400 kwh/year with an average of 450 kwh/month of that 3000 kwh/year is HVAC related. If 1 gallon of gas is suppose be equivalent to 33.4 kwh[1] then my 3000 kwh/year for heating-cooling usage equals to so 90 gallons of gasoline per year. My 2010 Prius burns about 2oo gallons of regular gasoline a year going 12000 miles/year at about 60 mpg so technically my Prius is my biggest energy user. Biologically - a gallon of gas is suppose to contain 31000 calories [2] ...way more than most people including me eat in week.
    [1] Gasoline gallon equivalent - Wikipedia, the free encyclopedia
    [2] HowStuffWorks "Is there a way to compare a human being to an engine in terms of efficiency?"
