When is ICE Running?
Discussion in 'Gen 3 Prius Main Forum' started by 1bikeman, Jul 10, 2014.
  1. 1bikeman
    1bikeman Junior Member
    SoCal
    We recently purchase a clean used 2010 Pkg 2. It has been a better car than I had anticipated. Not just a good green car/hybrid or great on gas.....it's a good car! This forum provided a lot of answers to our questions prior to purchased, and even more afterwards. I really appreciate all the knowledge I have gained.
    I apologize, and thank you, in advance for this dumb question. I did a search of this forum, Google and several sections of the Owner's Manual before posting this.
    How does one determine visually when the ICE is running? Specifically, where is this indicated on the display? I can sometimes tell when the ICE is running, but other times I'm not sure.
  2. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    The ICE is running if the EV symbol isn't showing on the dash.
  3. fuzzy1
    10,335
    OP's 2010 doesn't have that EV symbol on the dash. Or least, my identical year-level did not.
    That symbol was added in 2012 as part of the mid-cycle refresh.
  4. 3PriusMike
    3,089
    2,411
    Silicon Valley
    There is no direct display for this. If you are showing the simple animation that shows power flow, you can tell the ICE is one when the arrows show power going out of the engine.
    Mike
    #4 3PriusMike, Jul 10, 2014
    BrianPB likes this.
  5. Dancing Badger
    Dancing Badger Junior Member
    Manchester, England
    Business Ed. Plus
    When the instantaneous fuel consumption gauge indicates anything other than maximum (100 mpg on my UK spec car) the ICE is running.
  6. fuzzy1
    10,335
    However, there can be times when it shows 100 mpg and the ice is still running. While not frequent, it does happen.
  7. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    gliderman likes this.
  8. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    EXACTLY! Look at the HSI Indicator. When EV is not lit, the ICE is burning fuel. Cut and dry. No mysteries here.
    Ice is OFF when HSI looks like above.
    Ron (dorunron)
    hybridbear likes this.
  9. tv4fish
    tv4fish Member
    202
    46
    I agree - get yourself a Scanguage and mount it right on the dash behind the upper middle of the steering wheel. It's a cool "tool" to keep track of 4 things (you get to choose which ones) to monitor. It's cool when you start to go down a hill and the Scangauge shuts off. That's when you know the ICE is NOT operating. :)
  10. fuzzy1
    10,335
    That's when you find out that your ScanGauge is not set up right for a hybrid. I don't recall just which menu setting needs to change (its in the manual, which I read five years ago), but you shouldn't have to tolerate it winking out periodically while driving.
    I prefer to watch RPM to determine when the ICE is burning fuel, but GPH and some others can also work.
  11. drysider
    drysider Active Member
    823
    335
    Liberty Lake WA
    You need to go into the ScanGuage set-up and configure it for a hybrid. It won't shut off after that.
  12. Mendel Leisk
    40,472
    When the instantaneous fuel consumption gauge (circled) is up to the top (or down to the bottom with liters/100km), and you're below ~45 mph, the engine's off. Above 45 mph my Scanguage will show minimum 900+ rpm, but the IFC gauge (and Scangauge) will show no gas being consumed. So maybe it's just turning over.
  13. fuzzy1
    10,335
    On US models, scaled in MPG, that is not definitive. In certain circumstances the car can be burning fuel as low as 0.2 gallon/hour, getting 100-300 mpg, and it will still peg that display the same as the no fuel condition.
    If your Canadian (or almost anywhere else in the world, except Japan) car is scaled in liters/100km, then this display should be definitive, as either zero or not-zero fuel consumption.
    This is another reason I hate the US MPG scale. If we can't go metric, then at least we should replace MPG with Gallons/100miles. That would get rid of many misunderstandings among the non-mathematician consumers.
    On my Prius, 992 rpm means no fuel. Any fuel burn displayed on GPH appears to create a higher rpm.
  14. drysider
    823
    335
    Liberty Lake WA
    You can configure the "Cutoff" parameter on the ScanGauge to watch the fuel flow. The gauge will also accurately show the instantaneous mileage up to 9999mpg....well past the cutoff. It can also be configured to read l/100km, although I have not personally tried it.
  15. bisco
    51,028
    impossible to know...
