Independent Prius Mechanic recco / Torrance CA?
Discussion in 'Gen 2 Prius Main Forum' started by blacktouring, Oct 13, 2012.
  1. blacktouring
    blacktouring Junior Member
    45
    Rolling Hills Estates
    Anyone have an independent prius mechanic they can recomend in the Torrance/South Bay are of CA? I've already have searched but didn't find anything. TIA
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  3. blacktouring
    45
    Thanks for your prompt reply - I can vouch for Avi - he is awesome!!! I had trans fluid in my inverter cooling system. Dealer flushed the system, but it happened again - so they told me I had a leak somewhere between the trans and the inverter and that I needed a new trans! Avi was the only one who determined that the issue was previous owner placing trans fluid into the inverter cooling system. Avi thoroughly flushed out my inverter system and I've had no issues since (over 30K since). But he's over 35 miles from my home :(
  4. blacktouring
    45
    I should add that he's very reasonable price wise - very trust worthy.
  5. lr08
    lr08 Junior Member
    Avi sounds great, but he's quite a hike for us in the South Bay. This is an old thread, so I thought someone might have discovered another Torrance/South Bay Prius mechanic. If I can't find a recommendation here, I'll try Lexology in Redondo Beach and report on my experience. My issue is that the A/C is blowing warm, but I'm looking for an honest general mechanic that knows our Prii inside and out. Any help is greatly appreciated!
  6. GKuma
    GKuma Junior Member
    45
    Castaic, California
    I heard Lexology is good from another Prius owner, although I have no experience with them.
  7. lr08
    lr08 Junior Member
    Thanks, any others? With the North American headquarters of Toyota in Torrance, there has to be a guru level Prius mechanic that set up shop somewhere nearby...
