Ebay Fogs installed today
Discussion in 'Gen 3 Prius Accessories and Modifications' started by John Bergendahl, Jul 31, 2014.
  1. John Bergendahl
    102
    17
    gulfport,ms
    Installed my Ebay fogs today so far so good.Really like the look the car has now.I have the DDM Tuning 5000k 35w HID kit in the headlights and reg bulbs in the fogs.
    xliderider and Burna J like this.
  2. xliderider
    xliderider Senior Member
    8,044
    3,217
    Honolulu, HI
    Yes, regular halogens in the fogs. (y)
    Too much glare if HIDs
    are installed in the reflector based foglights.
    SCH-I535
  3. John Bergendahl
    102
    17
    gulfport,ms
    Excuse the bright glare from the headlights,LOL camera and 5000k HID dont do well :)
    This combo looks really good at night in person.
    I had this same setup on my 2010 Altima 3.5 SR she was white also so i had to do this setup again .
    I agree with you totally,my altima didn't have projectors but it came stock with the HID's and they had no blinding effect.I guess it was a some special reg housing made for HID's
    C.R.E.A.M. likes this.
  4. cheizy
    cheizy Member
    94
    129
    Los Angeles
    Looks good, how hard was the wiring since it was an ebay item and not oem? Any install guide you used?
  5. dle
    dle Junior Member
    65
    SoCal
  6. xliderider
    8,044
    3,217
    Honolulu, HI
    The hardest part, IMO, is running the wiring through the firewall grommet.
    SCH-I535
  7. John Bergendahl
    102
    17
    gulfport,ms
    Well I must say that the wiring i got was not like any other ones i have seen.But if you know what connects where you can get the job done.I have the power connected to the actual positive spot in the fuse box under the hood and the trigger connected to the parking brake.the 2 negative wires to a random bolt and of course the button through the fire wall.Only thing i don't understand is why the button does not turn the fogs off.... they come on when i turn parking lights on and Im ok with it like that for now... Has anybody else ran into this? the switch has 4 wires so its not like i can just buy another switch to fix this ...
  8. xliderider
    8,044
    3,217
    Honolulu, HI
    Parking lights, not parking brake, right? ;)
    Sounds like you don't have the switch wired correctly.
    SCH-I535
  9. John Bergendahl
    102
    17
    gulfport,ms
    Opps yea i meant parking lights LOL
    power wire to positive battery terminal
    trigger wire to parking light
    grounds to grounding location
    relay to relay plug
    there is NO other way i could have wired it wrong unless the button is faulty...button lights up just doesn't turn off when pressed.I mean its no biggie I'm sure i could add a switch by spicing one of the wires going to the button and adding a switch. since the button is acting as something that simply connects power....
  10. xliderider
    8,044
    3,217
    Honolulu, HI
    Test the switch leads for continuity with a multimeter.
    SCH-I535
  11. John Bergendahl
    102
    17
    gulfport,ms
    Well Im not very educated when it comes to trouble shooting these kinds of things I don't even know what I'd be looking for...I'm a basic install guy.LOL
