Does anyone have a Prius Plugin with a roofrack & box
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by inferno, Aug 2, 2014.
  1. inferno
    inferno Senior Member
    1,072
    405
    and how did that effect your efficiency. Just curious if any of you plugin owners did it and still just love the car and versatility without any worries (and of course loves the fact it plugs in!)
  2. vskid3
    vskid3 Active Member
    773
    228
    The hit in efficiency should be similar to a regular gen3. If they lose 10% of their MPGs, you should lose about the same for MPGs and EV range.
    Look into adding a hitch and using a rack/box on the rear. Shouldn't hurt your mileage and may even help a bit if its shaped and sized right.
  3. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    The system is more efficient and more flexible to begin with. So, it isn't similar, nor does it matter anyway.
    Why would recreation/vacation be of any efficiency concern? It's such a rare opportunity to get to escape. When you see a chance, take it. Don't worry about a hit when you are doing something that only happens on special occasion.
    53 MPG is what I got the other day, carrying 2 kayaks without cockpit covers on top, for 37 miles using just a single charge.
    That was totally worth it!
    inferno likes this.
  4. inferno
    1,072
    405
    What do you get regularly with the racks and nothing on top? Is it that 73.3 MPG? That would be quite amazing considering people mentioning a regular Prius Gen 3 would get maybe 47 or 46 mpg, then again you do get to plugin more often ;)
  5. vskid3
    773
    228
    If it increases the drag by 10% (just theoretical) on a regular gen3, it'll increase the drag of a plug-in by 10%. That means the amount of energy required will be the same. So the mileage hit would be about the same after the plug-in's battery has run out.
  6. john1701a
    12,818
    5,303
    58
    Since it only takes a few minutes to put them on, there has never been a time that I've driven with them on empty.
    It's just a quick clamp on each side.
    You wouldn't want to keep them on even if there wasn't any MPG difference at all. They'd get gross, covered with squished bugs.
  7. firedoug
    firedoug Junior Member
    28
    Corona, CA
  8. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
    There could be a threshold where it is better to rent a boat (or what ever gear) at your destination then carry it on top of you car. Also, taking into account time, convenience, etc. Being in Utah we do some pretty long road trips to get to destinations.
