Folding mirror mechanism broke...how to remove mirror glass?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Beachbum, Jul 25, 2014.
  1. Beachbum
    Beachbum Junior Member
    22
    Hillsborough, New Jersey, USA
    For a 2007 Prius with power side view mirrors:
    The spring-loaded folding mechanism on my power driver's side view mirror broke. Took the cover off (the painted part) and see that the large washer that sits on top of the big spring came off. Doesn't look like anything is broken, just that the washer that compresses the spring came off. Problem is I can't remove the mirror glass to get to it to put the washer back in. It looks like the mirror glass is held onto the motorized round part (the round part that moves the mirror) by 4 sets of 2 small clips each at roughly the 2 o'clock, 4 o'clock, 8 o'clock and 10 o'clock positions (total of 8 clips). Was able to loosen some of these clips with a small hooked tool and/or screwdriver, even broke a few off, but the mirror glass is still stuck fast. Not budging at all.
    So I'm thinking that the glass is glued on in addition to the clips. Can anyone confirm this? I really don't want to break the mirror glass to remove it. And I am trying to avoid having to buy a whole new power mirror assembly if I can fix mine. If it is glued on, is there any way to remove the glass without breaking it?
    It looks like a simple fix if I can just get the mirror glass off. Just push down on that washer to compress the spring and turn it into the locked position.
    Any help greatly appreciated. Thanks...
  2. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    The mirror glass on the Prius is removed by tilting the glass upwards then getting as many fingers as you can under the bottom edge of the glass and pulling firmly. the glass with it's plastic carrier should snap out and unhook from the top edge. There are two wires going to the heater on the back of the glass if it is of the heated variety.
    Hope this helps.
    John (Britprius)
  3. Beachbum
    22
    Thank you John but I had already found those exact instructions on Priuschat but they didn't work. I tried pulling the bottom edge outward as hard as I dared but it didn't budge, and was fearful that if I tried pulling any harder the glass would shatter in my hands. Maybe this method works for manual mirrors but I don't think it works for power mirrors. Or maybe it works for other year cars but not my 2007.
    Again, when I look up in there with a strong flashlight I can see the 4 sets of clips at the 2/4/8/10 o'clock positions holding the glass to the round motorized part that moves the mirror up/down/left/right. But pulling the clips out with a small hooked tool, and even breaking a few of them, did not loosen the mirror at all.
    So that's why I am thinking that the glass is also glued on.
    Can someone who has actually removed the glass from a Gen II power side mirror chime in here? Is the mirror glued on as I suspect? Any way to remove it without breaking it? A picture of the back of the glass with its plastic carrier would be very helpful.
    Many thanks...
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,532
    Southwest Colorado
    Sounds like a job to wear good protective gloves. They will give you more confidence to yank the mirror out, and protect your hands in case the glass breaks.
  5. Britprius
    5,194
    1,918
    Hear is a picture of the back of the mirror. The two claws that hold it at the bottom edge can be seen. These grasp very tightly onto round bars. The two hooks at the top of the mirror come free as it is tilted up. I hope this will tell you if they are the same or not.
  6. Beachbum
    22
    Thanks so much for the picture John. This confirms that this is NOT what my mirror looks like. This must be from a manual mirror, or perhaps from a different year. Mine is completely different - there are no round bars that it snaps on to. But at least I now know for sure that the "grab and pull" method will not work.
    So again...can anyone help me?
  7. Britprius
    5,194
    1,918
    The picture is from the mirror off my 2008 Prius with electrically operated glass movement, and is the same on all G2 model years as far as I am aware. Unless your car has electric folding mirrors that I believe were only fitted in Japan. I could be corrected here they should be the same.
    John (Britprius)
  8. Beachbum
    22
    OK, I think I figured out what's going on here! It looks like the mirror I have is an AFTERMARKET mirror. It must have been replaced by the previous owner. Because when I compare it to the passenger side mirror it is different (my passenger side mirror looks like the one in the picture above). And the passenger side mirror has a Toyota part number stamped into the black plastic on the underside, whereas the driver's side mirror does not...there is no part number at all. And the 3 screws on the underside of the Toyota part are Torx screws but on the other one they are Philips screws. So even though both mirrors look identical on the outside their internal mechanisms are completely different.
    So I think this explains my problem. And I do believe the glass on the aftermarket mirror is glued on so removing the glass without breaking it is impossible.
    Thanks John for all your help.
    Beachbum
  9. Britprius
    5,194
    1,918
    Sorry I could not have been more help, but your findings does explain things. It is possible the mirror got broken and was replaced with an after market unit rather than the genuine. After market parts often look the same and at up 60% cheaper are often a better buy. I was able to buy aftermarket heated mirror glasses for £12 for a pair. The Toyota none heated version " heated mirrors were not available on the UK Pius" were over £30 each at the dealers.
    John (Britprius)
