Time to replace tires, which one?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by FM_SC, Aug 9, 2014.
  1. FM_SC
    FM_SC Junior Member
    SoCal
    My 2012 Plug-in Prius is in need of tire replacement. It is at 54k miles as I have a 100 mile per day commute. Question is which tire should I go for. I always get my tires at Costco when they have $70 off for a set. Current special is for Bridgestone. They have an Ecopia model for a little under $100. I read some bad reviews for it. What is the collective wisdom for replacement tires. I care about safety first, then mileage and thread life.
    #1 FM_SC, Aug 9, 2014
    51,840
    michelin energy saver a/s.
  3. Okinawa
    Okinawa Senior Member
    1,333
    320
    Michelin Defenders is my favorite. 90,000 mile tread warranty. Very quiet and good handling tire.
  4. FM_SC
    FM_SC Junior Member
    SoCal
    How are they for mileage? I have seen to keep the current mileage I am getting, perhaps energy savers are a little better. What has been your experience with these?
  5. Okinawa
    1,333
    320
    I did not lose any mileage with Defenders. I think some people may have lost a little. I think if you do lose a little it is worth it for the quality you are getting but that is my opinion. I'm sure you will get some more opinions.
  6. kc410
    kc410 Active Member
    263
    252
    2010 Prius IV
    I got the Defenders from Costco on June 9 & have got ~7K on them - wonderful tire! Quiet!
    I had Toyo Versado eco & ran them at 44/42 psi.
    I decided to run the Defenders at 44 psi all the way around.
    The mileage hit I've seen is more from running the AC full time.
    June July Aug Sep is really hot here.
    A couple days when it has not been _really_ hot I've not run the AC & the mpg jumps back up to close to what I was getting on the old Toyo tires.
    Running the tires at max sidewall pressure seems to be the key to max mpg.
  7. Mendel Leisk
    41,315
    Could you at least spell out the name of that tire? EP20, EP422? Or?
    And clarify "a little"?
    Sorry, grouchy ;)
  8. frodoz737
    frodoz737 Top Wrench
    4,694
    2,494
    33
  9. ImitationKrab
    ImitationKrab New Member
    Long Beach, CA
    I have Goodyear Fuel Max tires on my 2013 Prius Plug-in. They are what came with the car. Granted I live in a place with moderate temps and no extreme weather, but they are serving me just fine and aren't too expensive (had to replace one).
    That said, I think Michelin makes a superior product, but if the price is right, I think you could be fine on either.
  10. FM_SC
    FM_SC Junior Member
    SoCal
    Sounds like Michelin Defender is the one to go with. They are not on sale at Costco this month, but the price is reasonable, I think around $115 per tire, so I will go with those.
  11. Okinawa
    1,333
    320
    You will like them. Good handling, quiet, comfortable and long mileage.
  12. FM_SC
    FM_SC Junior Member
    SoCal
    I hear people are saying this tire would result in about 5-7 mpg drop. That sounds a lot. Have you experienced this?
  13. Okinawa
    1,333
    320
    No, I did not experience any change in MPG. Even if you do experience a slight drop that should change when the tires get broke in at about 1,000 miles or so. For the quality of the tire I would not be concerned about it. You are going to get about 90,000 miles out of them. $115.00 each is a good price.
  14. kc410
    kc410 Active Member
    263
    252
    2010 Prius IV
    see post #5
  15. Okinawa
    1,333
    320
    If you are worried about it you can called Michelin Customer Service at 1-800-846-3435 and seek their guidance. I call them and ask for their advice when I purchase new tires.
  16. FM_SC
    FM_SC Junior Member
    SoCal
    Sounds like some of those 5-7 mpg lose cases may be rare. I will just go with these and call it a day. I am not that obsessive about tires. Sounds like this one is a good compromise in my case. Thanks again for sharing your experience.
  17. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I think you'll be happy you did NOT get the Bridgestone.
    I talked to "The Guy" at the tire shop at Costco. And let me put it this way.....he REALLY did NOT want to sell me a set of those. He more or less recommended ANYTHING but those.
    Now maybe he was just a grumpy non-fan of the product? But when the guy selling them, more or less goes...NOoooo! You don't want a set of those...I'd be hard pressed to buy them.
  18. Okinawa
    1,333
    320
    I'll tell you one tire that I would not have if they would give me a free set and that is Bridgestone. The Bridgestone Turanzas came on a new 2007 Camry that I bought. They are crap. In the winter when I first drove my car in the morning they rode like they were perfectly square. Just horrible tires. I am strictly a Michelin person. Never had a bad experience with any Michelins and I have been buying them since 1976.
  19. Mendel Leisk
    41,315
    If I may: a specific Bridgestone tire that I cannot say a bad thing about, is reasonably priced and readily available, and has very low RR: Ecopia EP20.
    The only fault: I would not use it, particularly once worn, in any significant snow. For me that's a non-issue, switching to snow tires.
    I've purchased them twice for a previous vehicle (still in family) requiring 195/65R15; they've given long life and LRR.
  20. MikeDee
    MikeDee Senior Member
    1,576
    596
    San Francisco Bay Area
    I think you are the only one on this forum that claims no loss of mpg with these tires.
