Engine air filter barely dirty after 2 years / 40K
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jonny Zero, Aug 10, 2014.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    There is not a whole lot of dust where I live and the Prius does not use much fuel. Toyota says 30K or 3 years. I am keeping mine to 60K 3 years. More concerned with the rubber parts getting brittle in the heat and break off, than the element itself getting clogged up.
    51,042
    it's amazing, isn't it? what could toyota have done to facilitate this, a pre filter?
  3. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Just goes to show how little the engine actually works in comparison to the standard ICE machine. I too have noticed how clean the air filters stay on the Prius. I still changed ours once a year just for practical purposes. The filter is not real expensive, easy to swap and gives you peace of mind knowing you are getting maximum air flow and maximum filtration also.
    Just my two cents worth.
    Ron (dorunron)
  4. bisco
    51,042
    good point, i hadn't thought of that!(y)
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    On the filtration point -- new filter is less efficient than an used one -- trapped particles act as additional filtration medium. This is the main reason I am sitting on mine. ;)
    HaroldW likes this.
  6. dorunron
    3,318
    1,105
    Houston, TX
    Hmmm, that may be. However you are forgetting that the computers will adjust the air/fuel ratio and the valve timing to allow for that "DIRTY" air filter. The filter is NOT expensive, real easy to change. And who is to say that the Prius is not operating as efficiently and as clean as it would be with that dirty filter in comparison to a new filter?
    To each his own.
    #6 dorunron, Aug 10, 2014
  7. Former Member 68813
    3,524
    983
    US
    Dirty air filter had impact on carburated engines that had no feed back from oxygen sensor, made them run richer. Now, filters have no impact whatsoever in modern engines. Under normal driving, the throttle air resistance is much grater that the dirtiest air filter. In theory there could be some power increase under WOT, but probably too little to measure.
    And yes, if prius MPG is roughly double of regular car, half as much air will flow through the filter.
  8. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    My Toyota dealer asked if they could just leave my air filter on for another 5000 miles, at 30,000 there was no sign of dirt in it.
  9. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Wow, a dealer which didn't want to sell you unnecessary service, amazing.
  10. canta
    canta Member
    101
    Raleigh
    I think, the best way is just replacing with a new filter.
    If you do not want to replace, please check filter rubber to make sure no rubber breaks, and can seat properly without leaking on filter box.
    I always replace 2-3 years regardless the filter is still clean or not. filter is very cheap and easy to be forgotten..
    once for awhile (my area), Toyota(dealer specific), send flyer for discount (mostly 10%) or discount on oil-change or maintenance service discount. I always wait those flyers to get discounts :D. 200-300 miles late is not a biggie deal on oil-change.
    I never got those discount flyers while owned Hyundai...
  11. Mendel Leisk
    40,497
    ^ Just picked up a cabin and engine filter for a Honda. The effing things were over $30 each... (Yeah, I know, aftermarket's cheaper. I just didn't want to run around, and wanted all the maintenance items on one bill.)
    Our Prius filters are coming up for replacement, by the km interval. Got to say the last time I checked the engine filter it looked like new. The cabin filter had a few bugs and seeds on it, but I'm not too concerned about it. I'll likely change them, just to stick with the schedule, though.
  12. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    It's the cabin filters that get filthy & should be changed every oil change.
  13. Mendel Leisk
    40,497
    ^ Cabin filter condition is somewhat dependent on AC use I think. If you frequently just leave the system off and run the windows down, not so bad.
  14. Dark_matter_doesn't
    691
    151
    Seattle, WA
    I hardly ever use A/C, and the cabin filter is filthy every 10k miles.
  15. Spindifferent
    Spindifferent Member
    155
    79
    Central Texas
    Air compressor, meet filter.
  16. Mendel Leisk
    40,497
    ^ That's actually in the Owners Manual, page 458. My take, clean with air once or twice, if it's not too bad, then replace the next time.
    quantumy likes this.
  17. OptimusPriustus
    OptimusPriustus Active Member
    328
    137
    Finland
    For some reason the air filters in modern cars do not get dirty so quickly. Maybe because engine compartments are nowadays less ”open” or because the air flow through filter is upwards (dust and particles fall off). Or maybe the overall designs are just so good. In my other cars i have sometimes put the old filter back on because of so fresh looks.
    i dont think Prius filter stay fresh because of hybrid system. Car simply does not run on pure electric that much. Fuel consumption 4-5liters/100km so it sucks air as much as any normal car.
  18. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    In most cars these days, the intake air first passes through a resonator, and then into an air intake “box,” with the air filter on top of the box. The air moves UP through the filter, so dirt and dust can fall DOWN into the box. This probably helps the air filter last so much longer.
    xliderider likes this.
