Diagnosing hybrid system issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 944turb0, Aug 11, 2014.
  1. 944turb0
    944turb0 Junior Member
    CA
    I just purchased a 2006 Prius with 89k miles and it has a problem with the drive train and randomly losing all power on the freeway causing me to make emergency shoulder stops to reset the car.
    The symptoms are as follows:
    -red triangle on, orange circle with ! on, check engine light on, hybrid monitor green car symbol is red with ! in it
    -traction battery fan is ALWAYS on when car is powered
    -the car has never driven under electric power
    -shifting problems, sluggish acceleration and all power loss on freeway
    -hybrid monitor system lies and shows the battery full one second and empty the next
    Are these symptoms indicative of a traction battery failure, inverter or another component ? Or is the only sure fire way of figuring out my problem going to the dealership (which I'm not looking forwards to)?
  2. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    The DTC's need to be looked at but the symptoms you give are classic of HV battery failure.
    John (Britprius)
  3. Britprius
    5,194
    1,921
    Continuing to drive with the problems could likely get you stuck somewhere as the HV battery is also used for starting the engine. There is no normal 12 volt starter motor.
    John (Britprius)
  4. 944turb0
    CA
    Yikes, I drove the car 1800 miles like this from the auction lot I purchased it at in Texas.
  5. Britprius
    5,194
    1,921
    Have the DTC codes checked. I you get P0A80 this would confirm it.
    John (Britprius)
  6. Britprius
    5,194
    1,921
    If you intend repairing this yourself I suggest you buy a Mini VCI with Techstream software from Ebay or Amazon for around $25 this will give you dealer level diagnostics using an old laptop.
    John (Britprius)
  7. 944turb0
    CA
    I do plan on doing it myself. Thank you for this information.
    I have a question re: battery replacement. If my Prius is still within the warranty, the battery is free from any dealership?
  8. Britprius
    5,194
    1,921
    Bearing in mind I am in the UK the answer would be yes. I believe the same applies in the US, but the guarantee differs from state to state depending on if the state it was purchased in and kept in is a CARB state. The CARB states have 150,000 mile 10 year guarantee not transferable to non CARB states.
    John (Britprius)
  9. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Continuing to drive as the OP defines?
    Could get him killed.
    Randomly losing power on the freeway is dangerous.
    Emergency shoulder stops with a powerless vehicle?
    Please safely seek remedy as soon as possible.
  10. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    Since you live in the Bay area you should have it checked out by these folks:
    Luscious Garage | Hybrid Specialists
    They have been mentioned a number of times and seem reputable. If nothing else they will give you good advice.
  11. Britprius
    5,194
    1,921
    If the car is still under guarantee it would make more sence to go to a dealer. Although Luscious garage has an excellent reputation I do not believe they are able to carry out work free of charge under the guarantee terms.
    John (Britprius)
    #11 Britprius, Aug 11, 2014
  12. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    Agreed, just realized he might still be under warranty. But a second opinion would be useful. :)
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Surefire way is to log onto Toyota.com/owners and join and then using your vin look up the service record on your car. Any dealer repair and or recall activity will be listed there.
    You will probably see it's last dealer activity shows it was diagnosed with a bad Hybrid battery and was just out of Hybrid warranty. Car was probably traded in on the spot and you can guess where it ended up.
    If no mention of it there then run to the dealer asap as you may still be under factory warranty on the Hybrid Battery. It's 8 years/100K miles in your state no matter who owns the car.
  14. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Does the car have a "salvage title"? If so, I believe Toyota will not honor any warranty because of the salvage title.
    HV Battery Warranty:
    Non-CARB state = 8 year/100k miles
    CARB state = 10 year/150k miles (must have been purchased and registration maintained in a CARB state)
  15. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Good point and true enough but no mention of that in his post. If its a salvage title his issues are probably just beginning.
  16. 944turb0
    CA
    So I went to the Toyota website and the service information seems pretty vague. Is anyone getting more detailed results?
    I'm probably going to get it diagnosed and see what codes pop up.
    The car is clean titled, btw
      File size:
      66.5 KB
      322
  17. exstudent
    2,214
    905
    Torrance, CA
    See what codes are being generated. Midas, Autozone, other auto parts stores might be able to connect their generic reader to see if P0A80, as Britprius stated earlier.
    Sounds like you hit the HV battery lotto. Run to the dealership to cash in. Worst case scenario, you'll pay the diagnosis fee of $100 (avg price in my area). If its truly p0A80, you should owe nothing b/c its warranty.
    Mini VCI cable is a crucial tool if you plan to do any maintenance on this car; cable critical to do brake flush. You will need an old laptop with Win XP 32bit OS. Unless your very tech savy to make a Win 7 32bit emulate XP.
  18. ericbecky
    ericbecky Hybrid Battery Hero
    4,382
    3,244
    Madison, Wisconsin
    You may be able to call the dealer that did service in July and get more info.
    But the reality is that the symptoms certainly point towards a hybrid battery issue.
    If you plan on doing the repair yourself feel free to call if you have questions.
