TRD Plus Rear Sway Bar
Discussion in 'Gen 3 Prius Accessories and Modifications' started by teamsc10190, May 5, 2013.
  1. came_to_party
    came_to_party Junior Member
    48
    You were right! Didn't even take me five minutes.
    I loosened the bolts, bounced the car, tightened the bolts, and took it for a spin. Completely eliminated the noise and it even feels a little more solid now.
    Thank you all so much, my lesson learned here is to always read the instructions, especially if I think I know what I'm doing!
    MVPLRJohnson likes this.
  2. EGGS
    EGGS Member
    108
    NYC
    i backed my car up on ramps. blocked the front wheels and just stuck my chubby little fingers behind the strut . ther is no need to remove the wheels/ struts etc...
    whole install took 30 min including drinking two beers (y)
    car handles much better . great cheap mod. every Prius should come with one from the factory
  3. SuperMonkey
    SuperMonkey New Member
    Old thread... but are folks doing this without a torque wrench to tighten the upper end link bolt? I can't seem to find a way to get a torque wrench in place without removing the lower shock mount bolt. I backed the car onto ramps too.
  4. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    I chose to do this without unmounting the shock mounts. I wouldn't, as a matter of policy, go about advising people to ignore torque specs. Unlike torquing flywheel bolts, or head bolts, there isn't nearly the amount of precision involved with the stress limits of the bolts on the sway bar. I consider guestimating the torque on the upper mount bolts an acceptable risk relative to the payoff in terms of installation convenience.
  5. Calvinw
    Calvinw New Member
    San Jose ca
    2014 Prius Plug-in
    Would upgrade the sway and/or springs affect the alignment? I had changed shock and springs for my BMW and never got alignment right, and need to change tire every 15-20k miles.
  6. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    They sway shouldn't affect alignment, but lower will. I recommend buying camber bolts for the front and adding them to your install. Their relatively inexpensive and give you some adjustment besides toe.
  7. EGGS
    EGGS Member
    108
    NYC
    sway bar doesnt alter the wheel geometry . lowering the car with springs takes the wheels and does this /\ which causes shoulder wear
    i torqued the sway mount and used a ratcheting box wrench on the upper link .
  8. Totmacher
    Totmacher Honey Badger don't give a carp
    301
    110
    Mission Viejo, CA
    A set of crows feet will help with hard to reach bolts to Torque down.
    I'm not a huge fan of crash (camber) bolts; there are a few ways to adjust in the TRD springs on install to end with -0.4 to -0.5 degrees camber which is likely plenty for most. The last few installs I have done the alignment shop didn't even touch the camber, just toe.
    Bullet Salvador likes this.
  9. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    I have a 2010 Prius II I just purchased from my local Toyota Dealer with 45,000 miles, and new 195/65-15 Yokohama AVID Ascend tires on it. I have put a little over a 1,000 miles on it. I read a lot of posts that people are having trouble with the way the car handles at highway speeds and adding anti sway bars and other mods. I can take mine out on the interstate at 75 mph with 1 hand on the steering wheel and get a very comfortable and steady ride. No wobble shimmy or anything . In fact it handles better than my Honda CRV I traded in on it. Im beginning to wonder if the previous owner added some Mods to the suspension .
  10. EGGS
    EGGS Member
    108
    NYC
    crawl under it and take a look . the trd sway bar and springs are usually white so they'll stand out . then again if there even is a rear sway bar then you have one . because stock the car doesn't come with it lol
    lar.smith42 likes this.
  11. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    Interesting perspective. I have not heard of problems with camber bolts. Care to elaborate?
  12. lar.smith42
    203
    118
    Double Oak , Texas
    Dosen't look like any anti sway attached. Only one bar under rear just in front of rear wheel wells going from side to side. Maybe its just the tires but it shure holds the road nice at 70 to 75 mph.Feels good on corners and curves also.
    Love my Prius!!!!
  13. JordanReich
    JordanReich Junior Member
  14. reaction26
    reaction26 Junior Member
    39
    DC
    Jordan I'm willing to take it off your hands. How much you willing to let it go for? I am in dc.
  15. JordanReich
    $150 plus shipping or free pickup
  16. reaction26
    39
    DC
    I'm in va how much will shipping be? Brand new at dealerships are going for $223.76 with shipping.
  17. Bullet Salvador
    109
    44
    Los Angeles
    I got mine 25% off retail, $209.25 plus tax.
    Most Toyota parts stores give 15-20% coupons if you ask or look online at there website. On rare occasions they give 25-30%.
    Simply research your local Toyota parts place and ask to talk to the parts manager. I hope that helps. =]
  18. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    The reason they are referred to as "Crash Bolts" is because they are used after the car has been wrecked, to allow a greater range of adjustment, in order to get back to factory settings. The crash bolts are tapered, and are more likely to slip, losing the camber setting that has been dialed in.
  19. champion510
    champion510 Junior Member
    Do you have a part number? about to call my toyota dealer tomorrow!!!
    how much did you spend for install?
  20. champion510
    Just saw the install video here - looks pretty straight forward
