Current draw during charging
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Rhodrons, Aug 15, 2014.
  1. Rhodrons
    Rhodrons New Member
    Chessington, Surrey
    2014 Prius Plug-in
    I am just about to take delivery of my new PiP and I am trying to find out a bit more about the charging options. I will be charging from a 240V domestic supply. Has anyone used a current meter and recorded how the charge varies when charging the batteries from "empty"? I live in a house with old electrics and when I had a car for an extended test drive I got the impression that it was charging at about 1.5kW which would be about a 7 Amp current draw which would be ok. If it starts off at say 13 Amp and then falls then I might need to think of Plan B sooner than I anticipated.
    51,575
    welcome to priuschat! congrats on your new pip, you have a 240 supply that won't allow 13 amps?
  3. CharlesH
    2,796
    1,163
    Roseville, CA
    Just so we are all talking about the same thing, note that the OP is in the U.K., where household electricity is 240V, and there are LOTS of older homes with limited electric capacity.
    #3 CharlesH, Aug 15, 2014
  4. bisco
    51,575
    ah, thank you. british electric.:cool:
  5. bisco
    51,575
    surrey? anywhere near privet drive?:love:
    markabele likes this.
  6. 3PriusMike
    3,097
    2,419
    Silicon Valley
    Here is what the charging looks like from a public 240v ChargePoint
  7. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    Mine follows the graph above. 230V, 10A for the best part of an hour then drop to around 2.5A for half an hour or so, it varies.
    If you are unsure that your supply is OK for 10A, (it should be, it was designed for 13A continuously), because of age degradation get a sparky to give it a once over. Do you have a RCD in the supply? if not, once again, worth having one fitted.
    Have you explored the possibility of a free government subsidised, dedicated charging point? they will fix all the problems on installation. I used PodPoint but there are a number of suppliers out there (avoid British Gas)
  8. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    Interesting... 1.96 kWh is not a full charge. I suspect you know that :)
  9. Rhodrons
    Rhodrons New Member
    Chessington, Surrey
    2014 Prius Plug-in
    3priusmike - thanks for the graph. This is the first time I have seen one like this and it answers my query perfectly. 10 Amps is what my domestic supply will be asked to deliver. I have a recently installed 13 Amp standalone supply in my porch that I will use initially but my garage has a 13 Amp spurred supply that I hope to use long term. My problem with installing a dedicated Chargepoint is that between my mains incomer fuse board and the car port where I will keep the PiP is a living room wooden floor and a concrete garage floor. I doubt that the installers will look on this distance favourably as the extent of the work required to burrow will probably mean that they will lose money on the job. I would be happy to extend the garage spur to the carport but I am uneasy about doing this given the fact that this is a spur off the ring main. Your plot shows me what I need to plan for.
  10. Rhodrons
    Rhodrons New Member
    Chessington, Surrey
    2014 Prius Plug-in
    Bisco - nowhere near Privet Drive but my first car was a Ford Anglia 105E and I have a scar on my forehead from my childhood but magic was not involved just a bicycle and a brick wall!
    markabele and bisco like this.
  11. pwp1943
    pwp1943 PHEV Afficionado
    51
    Boston
    2013 Prius Plug-in
    Your Prius charger will draw about 10 amps, period. If you use the Toyota supplied charging cord which plugs into standard 110 volt house current it draws 10 amps. If you buy an aftermarket charger which charges at 220 volts it also draws 10 amps. The 220 volt unit will charge your PIP battery in less than 1.5 hours, while the Toyota supplied cable takes about 2.5 hours.
    As 3PriusMike shows earlier in this post, most of your charge is completed in about an hour at 220 volts. So if you are making a lot of short trips on the weekend, you can charge up to nearly full in an hour. If you go to the mall where there are chargers, same thing. In an hour of shopping you have a nearly full charge.
    But what does this mean for you? My over night, full charge shows about 15+ miles of EV driving on the PIP display. In an hour, the charge shows about 13.5 miles of EV driving on the display. These numbers come from the situation where you have fully depleted the PIP battery before recharge and the car is behaving like a standard Prius hybrid. At 220 volts you get nearly a full charge in about an hour.
  12. Rhodrons
    Rhodrons New Member
    Chessington, Surrey
    2014 Prius Plug-in
    Pwp1943 - do you know how the PiP knows whether it is hooked up to 110V or 220V for charging? I assume it has some sort of way of doing it or is a European PiP only able to charge at 220V?
  13. bisco
    51,575
    we can charge at 240v, there must be software in the charger?
  14. IanIanIanIan
    IanIanIanIan Member
    152
    56
    2013 Prius Plug-in
    It is a different EVSE 'brick' in the UK made for 230V for use around Europe. It is possible to take the US 110V brick and have it altered to 230V by a third party so I must assume that the onboard charger is happy with both 110 and 230V.
  15. pwp1943
    51
    Boston
    2013 Prius Plug-in
    Here is a photo of my 220 volt home charge station. The reason for the complex connector is that the charge station must communicate with the PIP. During this communication the PIP and charger exchange information. This information allows the charger to supply the correct current and voltage to the PIP. My charge station is made from a kit designed by engineers from the EVSE Google group. They can be found by doing a Google search.
    I modified their kit to show both voltage and current readings using digital meters. When charging the PIP, the meters read 240 volts and 9.7 amps. The kit has been working flawlessly since last Oct. There are several of these charging sources of these available commercially as well. They can be found by doing a web search for EVSE. EVSE = Electric Vehicle Supply Equipment.
    Paul
  16. CharlesH
    2,796
    1,163
    Roseville, CA
    The charger in the car can handle either 120 or 240V. This fact is irrelevant for the OP, who is in the UK, so 240v is all there is. (or 230V or whatever it is exactly). I am not sure if the EVSE provided in Europe can handle 120V. The actual wall plug for the European version of the EVSE is interchangeable to deal with the various plug types in Europe.
    #16 CharlesH, Aug 16, 2014
  17. IanIanIanIan
    IanIanIanIan Member
    152
    56
    2013 Prius Plug-in
    Does this help?
    CharlesH likes this.
  18. CharlesH
    2,796
    1,163
    Roseville, CA
    Looks like Toyota also went on the cheap for the European EVSE, as it did for the North American version, with a fixed input voltage device. :rolleyes:
  19. CaliforniaBear
    1,180
    289
    Northern California
    Wow! Those UK connectors look like they're good for 100 amps. Yes, I know there's a fuse in there somewhere. :)
  20. Astolat
    Astolat Member
    229
    73
    Guildford UK
    Not sure British Gas is offering charge points for free any more, their website says they now charge, though it is still subsidised. I had a slight admin snafu originally over dates, but the actual fitting by them was fine, and it's worked perfectly since. Chargemaster look as if they are still offering a free charge point.
    Rhodrons, you're right that distance from the consumer unit was important, but it might be worth at least getting them to come and see if they would do it, or what they would charge. It really is very convenient to just lift the connector off and plug it in, and saves wear and tear on the Toyota one.
    And that sky blue PiP you might see at Tolworth roundabout is mine, on my way to or from work...
