My brake shoes look great at 150k!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by windstrings, Aug 12, 2014.
  1. windstrings
    6,280
    378
    Central Texas
    My 2010 G3 prius... Never done anything to brakes... Pads still look great.... Thx Regen!
    [​IMG][​IMG]
  2. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    Wow! :eek:
    That's amazing.
    Montgomery likes this.
  3. bisco
    51,851
    pads, and thank you warm climate. the battery may hate it, but the brakes are happy!(y)
    scona likes this.
  4. MSA14
    MSA14 Junior Member
    74
    Metro Atlanta, GA
    Make sure to check the pad on the opposite side - just incase the wear is uneven.
  5. windstrings
    6,280
    378
    Central Texas
    Pretty funny, I have 4 hybrids, never done a brake job on any.. Even my 2006 with 216k, the dealer said 60 percent still left in back, 40 in front.
    jdcollins5 likes this.
  6. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    Good to hear! Thanks for mentioning the 2006 brakes.
  7. windstrings
    6,280
    378
    Central Texas
    I have a second 2006 with over 250k, don't know how much is left because my son drives it, but never brakes on that one either!
    wjtracy likes this.
  8. qdllc
    qdllc Senior Member
    1,375
    400
    I'd expect so since disc brakes use PADS. ;)
  9. Mendel Leisk
    41,335
    Even if the pads have lots of thickness, it's worthwhile perdiodically to pull them out, inspecting the caliper pins, and so on.
    (I'm kind of gobsmacked by your miles accumulated. We're at 47000~ kilometers, and usage actually declining. Starting to wonder why we have a Prius, lol.)
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I checked the front pads on our '04 Prius at 170k miles before my daughter took ownership and found about 8 mm left :)
    Unfortunately there was a detail I did not understand in pulling out the caliper pin so the re-greasing was not done. Next time.
    windstrings likes this.
  11. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    That's pretty impressive.
    I have a fairly heavy foot so I am down to 3mm on my front pads after 93k. My rears are still doing fine at 6mm.
    But quite frankly, brakes are so inexpensive to replace that it's hardly a selling point, IMO.
  12. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    You can save a couple thousand dollars on brake service on hybrids vs none hybrids during the life of the vehicle. So yeah, I'd use it as a selling point. The brakes will probably outlast the hybrid battery.
  13. Former Member 68813
    3,524
    983
    US
    +1, LOL!
  14. Michael Wood
    Michael Wood Active Member
    181
    118
    Boston, MA
    2020 Prius Prime
    Prius brakes are absolutely amazing. My 2015 Gen 3 has 123k miles on it. The only issue I've had with it is that the 12V died - easy fix. Recently I noticed that the brake pedal felt a little soft. I decided to replace the pads on the front. The rears looked like they have a little more meat on them. But the fronts were worn down pretty much to the limit - 123k miles on one set of pads is incredible..
    BTW - there was some uneven wear - the caliper slides needed grease.
    I replace the the pads with Wagner Ceramic from Amazon. I didn't touch the rotors. They looked fine. No problems.
    My logic with rotors is this - if you're not experiencing any pulsating or other rotor symptoms, and your rotors look and feel true, then leave them alone. A nice set of Toyota factory rotors are better than a cheap aftermarket set. If I'm wrong and I ultimately end up needing to replace the rotors it's not a huge job to do it - but this has never happened. The new pads conform to the old rotors.
    So the total cost of my front end brake job was $23. The rears will be a little tougher because I'll have to buy that square tool to screw the pistons in. That doesn't look fun on YouTube. Maybe I'll get 150k out of my rear pads.
  15. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    If you do the work yourself, I agree, brakes are very cheap. But most people spend $300-$500 per axle even when they don't get skinned alive. If they fall for the old "You have a sticky caliper routine" it can get very expensive. Brake job thefts are probably the most common thefts in the motoring world
    dig4dirt likes this.
  16. ASRDogman
    ASRDogman Senior Member
    7,547
    3,897
    You could rent the brake tool from autozone. Mine were easy to do.
    I was going to replace them, but after I had them out, they were almost as thick as the new ones,
    so I cleaned and lubed the pins, put new paste on the pads after cleaning off the old stuff.
    That was 50,000 miles ago. At almost 189,000 miles I think it's time to replace them. :)
    Either way, they are super easy to do.
  17. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    Thanks for the info. I've been nervous about it, but now I feel more confident. Wow - 189K!!!!
  18. windstrings
    6,280
    378
    Central Texas
    Checking in again as OP! This same car now has 287k miles!
    Brakes still doing great!
  19. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    Windstrings, so your brake accumulator pump is still original? No major component failures along the way?
    I worry about that brake pump because I can hear it cycling on every time I get in the car - it's the first thing I hear. Mine sounds ok so far.
    If I get 287k miles out of my gen 3 I'll be very happy. Attached are my front brake pad pics after 123k. My miles are mostly highway.
  20. windstrings
    6,280
    378
    Central Texas
    I've had two 2006, one 2010 prius's, & one 2013 Avalon & now one 2019 Avalon... All hybrids....
    Never any brake problems on any!
    One of my 2006's made it just over 300k before my son's worker crashed it and now it's gone.
    The other my niece crashed.. Think it was around 160k when it went to happy hunting grounds..
    The 2010 is still going strong.
    Both my O6's had to have main traction battery replacements "refurbs", but the 2010 is still on original!
    Prius's are amazing little cars as long as you don't hit anything... Indeed they are fragile, otherwise they run forever!
    Toyota makes good hybrids.
    SM-N960U ?
