Fuel Door Does Not Stay Shut
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by delek, Aug 21, 2014.
  1. delek
    delek New Member
    Brooklyn, NY
    Hi. I just bought a used 2008 Prius, which seems to be in excellent condition except for the fuel door staying open. The hinge works, but the latch does not keep the door closed.
    Any ideas on how to fix this?
  2. JC91006
    JC91006 Senior Member
    16,761
    8,562
    This is the first I've heard of this problem. Has the car been in an accident?
  3. Okinawa
    Okinawa Senior Member
    1,333
    320
    Try spraying a little WD-40 in the latch that keeps it shut. Could be that it is stuck.
  4. Thump553
    Thump553 Junior Member
    CT
    2020 Prius Prime
    The latch (on the fuel door) is a piece of sheet metal, it may have gotten bent so that the pin doesn't engage it. Just bend it back if that's the case.
    Is the latch pin (in the body) working properly when you pull the lever?
  5. usnavystgc
    3,159
    990
    Tucson, AZ
    I agree with Thump, the tab that holds it locked got bent. Bend it back.
  6. Mendel Leisk
    41,315
    There's some sort of cable running from the drivers door sill to the latch. Something hanging up with that?
  7. delek
    delek New Member
    Brooklyn, NY
    Thanks for your replies. I will check and let you know what happens!
  8. delek
    delek New Member
    Brooklyn, NY
    I thought I uploaded this picture yesterday -- it does not seem to have stuck.
    I looked at the pin that is operated by the cable into the fuel door well. Could it be broken off? It is very short, protrudes only about 1/8 inch, and barely moves when you pull the lever in the driver's compartment. Here is a picture:
  9. Mendel Leisk
    41,315
    Yeah that's not right. Took a look at ours; it's sticking out a bit more than 1/4".
    In your pic it looks kinda chewed up: maybe someone pried it open to siphon gas, sheared it off??
  10. bisco
    51,840
    from the picture, it looks broken off. mine is about half an inch long.
  11. bisco
    51,840
    mendel, your pic did not come through.
  12. Mendel Leisk
    41,315
    Didn't post a pic, or intimate I was going to. I was thinking about it, fwiw: maybe you have esp! :ROFLMAO:
  13. bisco
    51,840
    for some reason, i read 'take a look at ours'. senior moment.:cool:
  14. Mendel Leisk
    41,315
    You goaded me into action; been trying to post an image with an IPhone, but it seems to be broken. Posting in general has been a bit flakey, Prone to hang, the last few days.
  15. bisco
    51,840
    with danny at the meeting, probably gonna be a few days before things get fixed.
  16. northwichita
    481
    102
    29
    Wichita KS
    My pin looks that way when it got stuck in the open position, I used a needle nose pliers to pull it out, then used some dry lube spray, but it happened again. I then bent the flap on the fuel cover door in a little bit, until it just barely would catch on the pin, and now remember not to pull all the way on the fuel release lever, just enough to release the flap and haven't had the problem again.
  17. bisco
    51,840
    now that you mention it, mine is electric, no cable. the pin works similarly though.
  18. delek
    delek New Member
    Brooklyn, NY
    Okay I will try with needle nose plier. I used a long nosed plier but that did not grab the pin.
    Is it possible to trace the cable? Where do I have to look?
  19. bisco
    51,840
    have you been driving around all this time with your flap open?:cool:
  20. delek
    delek New Member
    Brooklyn, NY
    yes. It just stays open a tiny bit.
