Why does one of the ECU connectors not have a wire cover?
Discussion in 'Gen 3 Prius Technical Discussion' started by thordehr, Aug 23, 2014.
  1. thordehr
    thordehr Member
    71
    47
    Los Angeles
    It first stood out to me after I did the Inverter re-programming recall. I wondered if I hadn't seen it before or it had been removed during the recall and not replaced.
    Now I saw this picture in someone else's post and see the same exposed wires...
    http://img.photobucket.com/albums/v411/HAWAIIANBUILT/PRIUS%20III/000%20MODIFICATIONS/064%20ENGINE%20ROOM%20COVER%2011%2025%2012/IMG_6436.jpg
    This is on the driver side of the engine compartment with the rearward most connector being covered with a nice plastic sheath, but the forward one entirely exposing the wires and the backs of the weatherpac connections.
    Seems a bit odd. This is the same on everyone's?
  2. thordehr
    thordehr Member
    71
    47
    Los Angeles
    Nevermind, I see it is an available part. Hunting for one now.
  3. Mike500
    Mike500 Senior Member
    2,593
    767
    I imported a bunch of the newer "REMOVABLE" type about a year. ago. It took about a month to get my first one from Japan. It was the earlier JDM "non-removable type. The ones that I imported have the removal tabs. I have a few left, but I can't sell them here.
    Be sure that you get the ones with the REMOVAL tabs.
  4. Air_Boss
    Air_Boss Senior Member
    4,209
    1,187
    New Yawk
    Just FYI, Mike's "removable" ECU connector covers are the real deal...
    My590L and Mike500 like this.
  5. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    Those covers are used in Japan's domestic market IIRC, and I cannot understand why they are not standard issue here.
  6. Former Member 68813
    3,524
    983
    US
    Any pictures of those covers?
  7. Mike500
    2,593
    767
    Here's a few photos.
    Just make sure you get the one with the "removal tabs."
    Former Member 68813 likes this.
  8. Former Member 68813
    3,524
    983
    US
    This is very cool. You had to import it from japan? The S&H must have sucked big time. Do you have part number by any chance?
  9. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Just go to eBay, hint, hint... ;)
  10. Former Member 68813
    3,524
    983
    US
    Thanks, found it. Seller : lbakeland
  11. Mike500
    2,593
    767
    YEP! Won't do it again, though. It is expensive, nerve wracking and time consuming.
    I had to try it once just for the experience. Since I ordered a quantity I had to pay freight forwarding charges and Customs duty on them. I worked for Customs as a "cross designated" agent in the 1970's and 1980's.
    So, I kind of knew what I was in for.
    If you buy one from Japan, it is assumed that it is for "personal use" and falls under the "nominal personal use duty exemption."
  12. My590L
    My590L Junior Member
    42
    NorCal, CA
    Thanks for posting this info. Just got my new Prius a few weeks ago. Checked under the hood after reading this thread and noticed no cover also. I wonder why they aren't installing these at the factory if a cover exists?? Nonetheless, I ordered one tonight.
    It looks like all you need to do to install this cover is open the grey wire harness lock and pull up; put the cover in place, then re-seat the wire harness lock?
  13. Mike500
    2,593
    767
    Correct. It's that easy to install.
    Replacing or repairing that part o the wiring harness would be very expensive, should it be chewed by rodents.
    From what I hear from PriusChat members, rodent damage happens quite often with the Prius.
    #13 Mike500, Aug 27, 2014
  14. Robert Holt
    1,313
    889
    Personally, I am more worried about long term exposure to moisture and corrosion of those very thin wires and connectors. I would suspect that even increasing the resistance of some of the circuits or connections would lead to difficult-to-diagnose electrical problems.
    I have had sugar ants colonize my Miata twice and fire ants tried to colonize my old Volvo, but never rodents in cars yet, altho to be fair I have had birds build nests in both the engine compartment and rear stabilizer of my airplane, and that was a mess to clean up to be sure. Those caps really ought to be standard in US models.
  15. My590L
    42
    NorCal, CA
    Thanks Mike. I'm wondering if these were standard on the earlier model years, then eliminated in subsequent model years to reduce the production cost-per-vehicle?
  16. Mike500
    2,593
    767
    Don't know.
    All I know is that they are on all Corollas, Camry's, and RAV 4's I've seen in the dealer showroom.
  17. My590L
    42
    NorCal, CA
    I received the cover yesterday and tried to install it today. It appears the wire bundle from the harness is at a different angle than the opening on the cover. I tried to reposition the wire bundle to match the angle of the cover opening, but it looks like I am putting some strain on the wires and the connections. I am planning on cutting a corner out of the right side of the cover to let the wire bundle keep its current angle. The sheath that covers the wire bundle is long enough that itwould still run under the part of the cover I remove. Anyone else have this problem with their wire harness and cover?
  18. Mike500
    2,593
    767
    Over time, the wire bundle should conform, and there will be no strain. The "set" occurred, because there was no cover installed during production.
    I wouldn't cut it.
  19. My590L
    42
    NorCal, CA
    Thanks! After some gentle 'retraining' of the wire harness into the angle of the opening, I was able to install the cover. Just ordered another one for my wife's v!
    Mike500 likes this.
  20. GEN3PRI8
    GEN3PRI8 Junior Member
    31
    UK
    I cannot find it on eBay
