What wheels
Discussion in 'Gen 3 Prius Fuel Economy' started by fl8216, Aug 30, 2014.
  1. fl8216
    fl8216 Junior Member
    pensacola
    Need new tires, should I go with the 17" wheel (shown on front) or the standard 15" (shown on back)?
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Personal preference in my book. I like the 17"'s that came on our Gen III. Pictured in the my avatar to the left. They are wrapped with Michelin Primacy's.
    Whatever you do, make sure you run good LRR type tires on her, otherwise the MPG will plummet. Nice looking Prius you got there. Add the body side moldings and the lower chrome trim and she will look sharp.
    This is what ours looks like. Latest MOD/Addition Lower Door Moldings with Hybrid Logo | PriusChat
    Best of luck to you,
    Ron (dorunron)
  3. Jcgnic3man
    Jcgnic3man Junior Member
    31
    Charleston, SC
    I agree, 17" all the way bro. I just had stock frs wheels installed today 17"-215/45/17 tires.
  4. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :eek:Bad choice of "word" if you were selling you Prius with 17" wheels. I have 17" Prius Persona wheels on my Prius PIP. I can count on 50 mpg plus in ICE mode. Most here will agree to expect a slight reduction in gas mileage with 17" wheels, but as everything else, it varies.
  5. dorunron
    3,318
    1,105
    Houston, TX
    Well, the only thing I can say is this. I am driving a NON PIP Prius. Last tank came in at 56.8 And that is with those 17" wheels and LRR tires. Don't know what else to say. It is a proven fact that non LRR tires reduce the MPG in the Prius. Driving habits and other factors also affect it.
    Best Tank Yet on our 2013 Prius | PriusChat
    YMMV
    Ron
  6. Former Member 68813
    3,524
    983
    US
    This is not a question, but bragging, right?
  7. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)My point was your use of the word plummet. A slight drop in mpg is more accurate. That's with non LRR tires (Continental DWS) and 17" wheels. I'll take a quality set of all season tires over LRR.
  8. dorunron
    3,318
    1,105
    Houston, TX
    So, I guess you think upper 30's versus lower 50 is NOT plummeting? I have seen folks report numbers like that here on PC. And I am not exaggerating. Call it what you want to. It is a fact that NON LRR tires will cause the MPG to be lower than LRR tires.
    Honestly, IMO what is killing your MPG more than anything is your location. You are up north where it is a lot cooler. Whereas the OP is in the south like myself. Honestly though, I would be ashamed to own a PIP and only get 50 out of it. I have seen PIP's get 80 and higher on Fuelly... I thought the reason to own a PIP was to get better MPG than the non PIP. But I guess in some cases it just is not happening. You don't by any chance think your quality non LRR tires might have something to do with those low numbers now, do you? Also, since when was Conti's DWS better than the Michelin Primacy MXM4?
    Remember the saying YMMV...
    Ron
    #8 dorunron, Aug 30, 2014
  9. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)Low blow Bro. Too many assumptions on your part. Last fill up, 2839 miles on 9.6 gallons gas and charging over five months as a daily driver. Save the lecture for someone else. End of discussion.
  10. zebekias
    zebekias Member
    101
    35
    Greece
    It's a highly personal taste thing, for me the OEM 17" wheels on my 3rd gen Auris are the bomb. I believe the exact same wheels are offered on priuses.
  11. zebekias
    zebekias Member
    101
    35
    Greece
    By the way, my avg consumption indicator right now is showing 3.7 l/100 km which is 63.5 mpg, even though it has been relatively cool for a few days at around 25 C. So I wouldn't worry about the 17" wheels increasing consumption. I have the Michelin OEM tires which I believe are LRR, but I keep them at exactly 42/40psi front/rear measured in the morning when cold. I tried higher but the handling was dangerous.
  12. Goin2drt
    Goin2drt Junior Member
    Yorba Linda
  13. dorunron
    3,318
    1,105
    Houston, TX
    I don't assume. That makes a nice person out of you and me. I base my post's on what you said.
    Best of luck to you. If you don't like my post's, feel free to put me on your ignore list. I don't want to sound rash, but you were the one who started this garbage with your reply about my "choice of words". Sometimes it is better to leave things left unsaid.
    For now, I will agree to disagree...
    Ron
  14. fl8216
    pensacola
    Thanks for all the help. I'm leaning to the 17s" and will use the tire size of (205/50/17)
    its the closest to the standard size (195/65/15) I have found.
    dorunron likes this.
  15. Grren4ever
    Grren4ever Active Member
    347
    167
    17 inch wheels all the way! For me, I'd choose a 45 series sidewall. 50 is a bit too high. That's only me tho :)
  16. zebekias
    zebekias Member
    101
    35
    Greece
    OEM is 215/45/17, I'd stick with that.
    Grren4ever likes this.
  17. dorunron
    3,318
    1,105
    Houston, TX
    Exactly. Pay attention to revs/mile when changing tire sizes. It does affect the odometer/speedometer read outs.
  18. fl8216
    pensacola
    The 205's and 195's are within .45% in circumference.
