Could the key fob circuitry be put in another vessel?
Discussion in 'Gen 3 Prius Main Forum' started by DrPepperholik, Sep 8, 2014.
  1. DrPepperholik
    DrPepperholik Active Member
    342
    108
    Spartanburg, South Carolina
    Say I want to take my key fob apart, put the guts in something else, let's say a sonic screwdriver replica, would that work? Would it fit?
    acceleraptor likes this.
  2. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Answer 1) if you never need to press buttons, (you always keep the fob in your pocket) then yes, anything non-metallic you can put it in should be fine.
    Answer 2) If you need to press the buttons, I would work at encasing the entire fab in the new shell.
  3. DrPepperholik
    342
    108
  4. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  5. DrPepperholik
    342
    108
    That's way too big. :( I don't want to carry that around. At least a sonic screwdriver can fit in my purse.
  6. RobH
    RobH Senior Member
    2,373
    987
    70
    Sunnyvale, California
    It's easy enough to take the circuit board out of the keyfob. Just insert the end of the mechanical key into the screwdriver blade size opening at the end of the keyfob and twist. The case will open up, and the board can be removed. Or just follow any instructions for replacing the battery.
    The simplest protective enclosure for the circuit board would be one of those small ziplock bags sold for pills. Just don't sit on it...
  7. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    Take the mechanical key (with your house key attached) out of the fob. Leave the fob in your purse and keep the mechanical key(s) wherever you think is best.
  8. Dachlover63
    Dachlover63 New Member
    Just curious, Why? If you keep it in your purse what difference does it make how it looks?? Security? Or just Fun?? Not being critical, I just my like your reasoning. :)
  9. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    If you can get the Tardis version of the Sonic Screwdriver, you should be good to go.:)
    DrPepperholik likes this.
  10. acceleraptor
    acceleraptor Member
    229
    75
    Milpitas, CA
    2014 Prius Plug-in
    Not sure how similar yours is, but the circuit board for my fob is surprisingly smaller and better shaped for a "cylindrical" cross-section profile than the one from my old Sienna:
    width: 20mm (22mm including the battery bracket, which is moddable)
    length: 45mm
    thickness: 9mm (both battery bracket and chip foam rubber cushion are flush)
    JimboPalmer likes this.
  11. DrPepperholik
    342
    108
    For the sheer pleasure of saying that I can open my car with the sonic screwdriver. Can't tell me that wouldn't be awesome?!
    energyandair likes this.
  12. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
    tricorder has my vote....
  13. DrPepperholik
    342
    108
    That would be a good one too! Hmm. Now I'm going to look for one.
  14. Mendel Leisk
    40,497
    Considering the replacement cost of fobs, I'd try to let go of this notion.
