Questions driving in the mountains
Discussion in 'Gen 3 Prius Main Forum' started by MPGnutcase, Sep 10, 2014.
  1. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    OK --- so in the mountains how does the P preform up and coming down do I use the B mode going down or not? Any hints here please
  2. maurices
    maurices Member
    128
    37
    Sartell, Minnesota
    Exactly. I used the Power mode on climbs and used the B for braking going down long grades. This saves on the brakes not letting them get over heated. Heat causes premature brake pad wear and can warp the brake rotors.
  3. Okinawa
    Okinawa Senior Member
    1,333
    317
    I agree with the procedure Maurices uses.
  4. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    The power mode doesn't give you any more power. It just determines how far you have to press the accelerator to get the desired power. So it may "feel" better but that's about all. B mode going down is good once the battery is charged however if you had a PiP it would be a whole different story:)
  5. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    I still feel the car is much quicker in the power mode. The damn thing is quick off the line as well. I cannot make it fast in eco, it's a dog!!!. H
    MPGnutcase likes this.
  6. CaliforniaBear
    1,179
    289
    Northern California
    Yes, it may feel better. However there are lots of threads where it is made clear that all the Power Mode does is remap the accelerator profile so less push gives more acceleration but full push is the same. Or there could be a problem with your Prius.
  7. HaroldW
    716
    95
    It's funny how remap of the peddle makes it so slow. I guess my legs are not long enough. Damn thing almost feels like a sports car in power mode. Guess I will have to dig the stop watch up. I bet it will be slower in the quarter mile. Has it been tested at the track? H
  8. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    I found out that when driving in the mountains that on downgrades as soon as the battery SOC reached 80% the engine braking would kick in automatically without me having to select B mode with the shifter.
  9. HaroldW
    716
    95
    Mine does this as well. My gen 2 does not do this ever. H
  10. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Correct, B mode just allows keeping the friction brakes cooler before the battery fills. I recommend it on any descent over 600 feet tall. (2500 feet in a PIP)
    B mode just allows you to know in advance you are going down a big hill, the computer only learns it once the battery 'fills'.
    #10 JimboPalmer, Sep 11, 2014
  11. Okinawa
    1,333
    317
    It does make it quicker off the line.
  12. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Jimbo, I agree. I was playing around with trying to control vehicle speed on downgrades. Of course until the battery fills at 80% the regen braking will do a good job of maintaining speed. Engine braking cannot control the speed on long or steep downgrades so you will have to use friction braking at some point.
    I have not done enough mountain driving to determine the best combinations but will be interested in other's observations.
  13. CaliforniaBear
    1,179
    289
    Northern California
    What friction brakes ;) In the PiP when I did the maximum regeneration of 150 Wh per minute for 4 minutes using modest braking at around 50 mph the friction brakes never came on. I don't see how the altitude change in feet would make any difference at all until the battery is full. The percent grade is a different matter. If you need to go slower because the maximum regeneration rate doesn't hold you back enough, then friction braking is needed. Except (?) the ICE would do braking first.
    #13 CaliforniaBear, Sep 11, 2014
  14. Okinawa
    1,333
    317
    When you are going down a hill you can tell if you are "riding" your brakes and before or when you reach that point, put it in B mode.
  15. CaliforniaBear
    1,179
    289
    Northern California
    Not in the PiP. Its appropriately "riding" the brakes that charges the battery and gives you those free miles for later use.
  16. Okinawa
    1,333
    317
    I don't have a PIP so I am totally ignorant as to how they work so I know you are right on your comments.
  17. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I did mention it took a LOT taller hill. If we could ignore rolling resistance and air resistance, and we can't, then for a given height, all slope angles have the same potential energy. Potential energy - Wikipedia, the free encyclopedia
  18. Okinawa
    1,333
    317
    Sorry guys, I did not realize this conversation was about PIP's. I should not have made any comments. I'm out of here
  19. CaliforniaBear
    1,179
    289
    Northern California
    Its the slope (grade percentage) that requires the brakes. If the slope is steep enough friction brakes may be required in addition to regeneration braking (adsorbing potential energy) and ICE braking. If the altitude change is greater than required to charge the battery (more potential energy than can be used) then we just have ICE braking and friction braking. At that point ICE braking may, or may not, be sufficient depending on the grade percentage.
    Section 3-5 Potential Energy, Physics for Science and Engineering Students, The Blakiston Company, 1952 :)
    #19 CaliforniaBear, Sep 11, 2014
  20. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Okinawa,
    The OP has a Gen III, I have a Gen III and this thread is in the Gen III forum so do not feel bad. We just have some PiP users adding input to the conversation :)
