Android Pure 4.2 Radio Non-JBL USA install
Discussion in 'Gen 3 Prius Audio and Electronics' started by chickenhawk, Jun 28, 2014.
  1. leo415
    leo415 Junior Member
    17
    San Francisco
    Thanks for the video(y) Looks like cutting that internal mic is my only option. btw, what's the link you used to purchase your unit? Maybe in the future I can check if he/she is willing to sell me a new mic module.
    If I were to do it again, I think I would use a potentiometer as suggested by the OP. Or maybe look for a lower noise level 30mm fan on ebay. My 40mm one is 14db/A and I barely notice the noise. Maybe you can give this 30mm with 15db/A+/-10% a try: 2pin 30mm Brushless Mini Cooling Fan 3010s 30x10mm DC 12V 2 Wire Heatsink | eBay .
  2. leo415
    17
    San Francisco
    I took a different way than chickenhawk. When I did mine, I broke a tab when removing one of the rear trim. Fixed it by super gluing. There was also a dead screw but luckily I was able to slip in the camera and mount it. Removing the trims was a real PITA. It took me 3 hours w/o any trim tools lol. I had my camera power attached to the radio power instead so I get constant power. I also have a Y split adapter going to rear view and AV in so I can turn on rear view any time with this HU.
  3. mountaindays
    mountaindays New Member
    ashland or
    Can someone tell me the part number/ model number of the radio in the 2014 prius and the 2012 prius.....are they EXACTLY the same? Our new 2014 prius radio went out after 3 months suspiciously after picking car up from dealer after its 5000 mile service. They claimed impossibly related to the service. They replaced with refurbished 2012 radio (which warranty allows refurbished parts). The technology seems like it would be different...and upon backing up, now are screen is half black and half 7 what radio station we are listening to. Any insight would be appreciated. It does say 3.1.0. I dont know what it used to say with 2014 radio.
  4. Prius2012fl
    Prius2012fl Junior Member
    53
    Fl
    Good suggestion, I went with what looks to be same fan but it ships from the USA BP3010M5 Fan 5V DC 2P 30mm 10mm 30x10x10 10" Wire Terminal FL USA | eBay
    Any gotchas when replacing the fan? Any suggestions before I dig into it?
    I got it from this seller here Speical Sell Prius 's Car Dvd Player With Android System - Buy Prius 's Car Dvd Player,Cheap Car Dvd Player Product on Alibaba.com
  5. Prius2012fl
    53
    Fl
    Nice idea! Do you believe placement you have it in is as good as where the stock mic placement? My cable wasn't long enough so I ended up putting it right above the AC vents on the dash but looks kind of ghetto. I might take your approach if you recommend it.
  6. chickenhawk
    chickenhawk Member
    261
    96
    CA
    Well i came across problem after i cut internal mic.. The external mic never work cause the jack is either wrong or not long enough to plug into the radios plug. Freakin pissed.. So i had to drill the radio back plate and solder in the mic.. Yes it did work but it still sound like i wad talking far away at the placement i told you.. It would be nice and loud when i am 5 inches away.. So i dont know where to place it now.. I got tired and went to sleep.. Where did you get the mic from? Im gonna have to try another mic or figure out a setting
  7. Prius2012fl
    53
    Fl
    I tried placing it https://lh5.googleusercontent.com/-TgcIHQae7aU/VCQVw6KeNpI/AAAAAAAAEZ0/Qb5KeAkuU2E/w566-h755-no/IMG_20140925_091630.jpg but everyone tells me there is too much road noise and it sounds awful. I just bought another mic on eBay - Alpine CDE 136BT CDE136BT Bluetooth Microphone Pay Today Ships Today | eBay for $10.50 and will try mounting it somewhere else.
    Right now, I am trying to get the backup cam installed "Camera Fail Init Alarm" Not sure what that is about. Any suggests are welcomed!
  8. chickenhawk
    chickenhawk Member
    261
    96
    CA
    How are you doing the wiring for the cam?
  9. Prius2012fl
    53
    Fl
    I grounded to white and for power I attached directly to the red/blue on the bulb but not the red wire that connects to this.
    On the head unit, I just plugged into the yellow RCA cable called cam directly.
    Was I missing anything?
  10. chickenhawk
    chickenhawk Member
    261
    96
    CA
    Sounds like your camera failed..do you have something with video out like camcorder that will make sure your rev cam in works and the switching works when you go in rev
  11. chickenhawk
    chickenhawk Member
    261
    96
    CA
    Thats how i fig out my cam failed and ordered another one ..the one i posted here
  12. Prius2012fl
    53
    Fl
    When your camera failed, did the HU go straight to the Android home screen? Mine doesn't even try to cut to the backup camera. I don't see the camera fail message until the unit has already booted.
  13. chickenhawk
    chickenhawk Member
    261
    96
    CA
    Ok.. Maybe you did not hook up the rev signal wire from HU to the positive wire of rev bulb. That is signal to HU to tell it to switch over to rear camera even before it finish booting up..
  14. chickenhawk
    chickenhawk Member
    261
    96
    CA
    When u finish this check of wires reread post 130 to check if wiring is correct
  15. Prius2012fl
    53
    Fl
    Sorry for the dumb question but where do I locate the rev signal wire from the HU and then positive wire of the rev of the bulb? Wouldn't they be at the two different sides of the car.
  16. chickenhawk
    chickenhawk Member
    261
    96
    CA
    The reverse wire is orange black wire on main connector on HU in this pic on right and you hook that to the positive wire of the rev bulb of the car which is the same wire that supply power to the rev camera.
  17. chickenhawk
    chickenhawk Member
    261
    96
    CA
    Yes it would be at both ends of the car.. So you should have two wires running from HU to the back of car which is 1. Video cable for camera and 2. Reverse wire for video signal switch
  18. Prius2012fl
    53
    Fl
    Perfect! That worked. Thanks for setting me straight again :)
    I will let you know how the new mic turns out.
  19. chickenhawk
    chickenhawk Member
    261
    96
    CA
    No prob.. I will see if i can upload my audio check..but i still get a slight click click click in background when talking on mic. This only heard on the person that the driver is talking to..hense our prob with the mic..
    If you can record the audio call on the phone that you are calling. There are apps that you can install to record the call
  20. chickenhawk
    chickenhawk Member
    261
    96
    CA
    Also how is qual of image of your rev cam at night? Mines is grainy
