how to choose new fog-lights.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by bmparent, Sep 20, 2014.
  1. xliderider
    xliderider Senior Member
    8,042
    3,214
    Honolulu, HI
    Most aftermarket foglight lenses are glued on. The bakeable adhesives are different butyl type adhesives.
    SCH-I535
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    but does that mean you can bake an oem fog lamp?
  3. xliderider
    8,042
    3,214
    Honolulu, HI
    I don't think so. They're also glued together. At least not with the gooey black butyl adhesive.
    SCH-I535
  4. 69shovlhed
    2,170
    751
    Delaware
  5. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    I bought the Ebay kit to replace one broken fog lamp. The kit was very comprehensive with wiring loom switch, relay, bulbs, grills, and 2 lamps with adjuster mechanisms. The lamps were indistinguishable from the OEM, and the complete bundle was less than 1/3 the price of one Toyota OEM lamp.
    John (Britprius)
    Daves09prius likes this.
  6. thegoldenhand
    thegoldenhand Junior Member
    44
    California USA
  7. 69shovlhed
    2,170
    751
    Delaware
  8. thegoldenhand
    44
    California USA
    ah ok... oe replacements. I think so long as it's not one of those ebay units where you have to do some rewiring and stuff, it should be ok. has to be plug in play with the current connections.
  9. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    You could always retrofit like I did... Hella Micro De Fog Light Retro-Fit | PriusChat
    Or...Go with some Yellow lens fog housing...
    Which is what I did on my 2007 until I get my new Hella fogs mounted.
    I did bake my fogs in the trial run retrofit - had i been more patient it would have worked, however i got hurried and slightly chipped the edges of the lens while lifting it with a screwdriver. I ended up having glass cut to fit the lens and went on my merry way.
