ICE not running -- Car stuck on forest road
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, Sep 21, 2014.
  1. writes123
    writes123 Junior Member
    92
    Riverside, CA
    Have you checked out priusdiy.com for instructions and pictures of the MAF procedure? It has some helpful tutorials with pictures for that and other simple maintenance items.
  2. ETC(SS)
    7,134
    I'm going to need some more Popcorn.........
  3. cyberpriusII
    1,155
    1,763
    Mars Hotel
    Yeah, soooo sorry. Have to agree this reading a bit like a soap opera....although I think bonbons are a bit more appropriate than popcorn for soap operas!
    But, buried in here are some real gems of advice. Helpful for everyone that actually may face the same problem. So, that is good.
    The final word from Toyota: $520. Could find no "problem" that would cause the no-start issue.
    They are replacing the water pump and the snake belt. They cleaned the MAF, they checked some other things that I already forgot about.
    And offered to put new windshield wipers on for $40.
    I declined the wipers. But, I was expecting $700 or so, so cannot complain too much.
    Thanks again everyone.
    Oh, they did say that this was not an uncommon happening. Sort of a Phantom no-start.
    So, in the spirit of my favorite weekend radio show "CarTalk," and their STUMP THE CHUMP segment, I have to give the award for the best answer to:
    USNAVYSTGC who said that it was just a stupid glitch and nothing was really wrong!
    And runner-up awards to all the rest who responded.
    Oh, additionally, I did get a mini-vic out of the deal, which I decided to keep, even with the cracked CD that did not work. Now, I just have to figure out how to use it on the Camry -- it tells me the car is an ACV and then gives a list of three different numbers and asks me to specify which of those numbers is my "option...."
    #63 cyberpriusII, Sep 29, 2014
    usnavystgc likes this.
  4. ETC(SS)
    7,134
    Oh...we won't reach the final chapter of this story until you return safely from Iowa...which is the ending that I'm hoping for...... ;)
    cyberpriusII likes this.
  5. cyberpriusII
    1,155
    1,763
    Mars Hotel
    I was thinking you were hoping I'd never return....
    At any rate, I won't be returning for several years, and maybe never....by then I will be a big pharma exec and driving a -- oh what's a good CEO vehicle -- a BUICK!!
  6. usnavystgc
    3,159
    990
    Tucson, AZ
    I love getting awards.
    Thank you so much. :)
    HaroldW likes this.
  7. Patrick Wong
    18,200
    6,500
    Before you declare victory and say your car is ready for your long road trip, you really need to log a few hundred miles via local driving trips. We know the dealer tech could not find a problem after an hour of checking around. So there is no obvious problem. However intermittent issues are not obvious.
    "Phantom no-start" - I disagree that this is a common happening - I have 182K miles on the 2004 and 73K miles on the 2007 and have not ever had a P3191 engine no start code. When that code is logged there is usually a good reason for it.
    Classic Prius, which is just one or two steps above a science experiment, has been known to have issues like this. But that model is not as fully developed as 2G.
    A good idea to keep the Mini VCI around. That, your fully-charged laptop and cell phone should be your traveling companions for a while.
    #67 Patrick Wong, Sep 30, 2014
  8. Former Member 68813
    3,524
    983
    US
    I've heard that oil overfill can cause no start condition. Was that looked into?
  9. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Kris said the oil was at the "3.5 quart mark", though to be honest I'm not entirely sure what that means. My dipstick doesn't have quart markings on it, but I assume that it's somewhere between the low and full marks.
  10. uart
    uart Senior Member
    4,220
    1,211
    Australia
    I totally agree Patrick. Failed HV batteries are "rare", but yet we have literally dozens of them reported here (on the forums) these days. Failed transmissions are even rarer, but we see enough of those reported too. But "phantom" cases of engines failing to start, without any actual cause. Hmm, can't remember reading even one single case of that happening with the Gen2.
    It's pretty simple really. The dealer service dept can either take your money and say "yeah we're totally clueless too", or take your money and tell you "everything fine, no real problem it was just a phantom" to make you feel better. The latter sounds better.
    #70 uart, Sep 30, 2014
    valde3 likes this.
  11. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    I checked our 2006 G2 for signs of leakage at the water pump and sure enough it has a couple areas with pink powder built up. Checked too see how much had leaked out, but it was still full. 70,000 kilometers on car. I don't feel I will change the pump at this time. Is this a typical issue with Toyota pumps? H
  12. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yeah quite a lot of people have reported seeing that build up. It appears to be that if there's even a really gradual seepage then you can get some amount of pink crusting there. My opinion is that if it's seeping so slowly that you can't even notice any loss in the radiator or reservoir then it's probably not anything even remotely urgent.
    usnavystgc and HaroldW like this.
  13. cyberpriusII
    1,155
    1,763
    Mars Hotel
    Agree with UART.
    While doing research on my coolant loss in the last week, ran across a number "articles" on the web that said that slight weeping on the Prius was not uncommon and no cause for any alarm as long as the coolant level seemed to mostly stable. Apparently a small amount of coolant goes a long way in terms of making "deposits" and odors.
    However, in my case, while the engine had never overheated, my coolant level was down signficantly and I know I checked it "sometime" in the summer (in other words two months ago, more or less).
    Replacement pump, coolant and labor at the dealer was $450. Patrick's tutorial is good if you want to go at it yourself....or an independent shop could easily do it.
    I could not quickly find any of the web references on the pump weeping issue that I mentioned, but here is Luscious' take:
    Luscious Garage | Blog | Gen 2 Prius Leaking Water Pump
    Any, yes, my oil level is at "halfway" mark as UART mentioned -- which to me is about 3.5 quarts (US).
    HaroldW and usnavystgc like this.
  14. JC91006
    JC91006 Senior Member
    16,762
    8,562
    Wow this thread is still going strong. Where's the popcorn?
  15. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
  16. ETC(SS)
    7,134
    Health Nazis Beware!
    I use real butter.
  17. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Kris I noticed you posted about finding mice debris along the top of the engine on 9-14 in the General section of the forum.
    Few days later here the car dies so makes me think def mice damage. Check entire intake again including snorkle main air in tube.
    Not sure what all the hubub about the maf is all about. Even if you completely disconnect the maf and start the car it will run just will stumble when you give it gas. It will throw a check engine light but not all the lights your seeing. I know as I left the maf disconnected once after a tb clean. No big deal plug it back in and 3 starts later the cel goes out. The maf rarely causes issues. I have never had to replace one in my life.
    I'm with Pat your car threw a Master Warning in addition to other cel's. This car does not do that lightly. I believe you still have not found the problem so don't start off on your big adventure just yet.
  18. Patrick Wong
    18,200
    6,500
    The distance between the top and bottom dimple amounts to ~1.6 US quarts. If your oil level is halfway between those two marks, then the engine roughly has ~3 US quarts of oil, assuming that the top dimple amounts to 3.9 US quarts. This is rough because the crankcase doesn't have a symmetrical shape. Therefore a 1/8" drop near the bottom dimple may require less fluid to disappear compared to a 1/8" drop at the top dimple.
    This is OK as long as you check the level in the radiator itself, not just the overflow tank. Sometimes the leak will allow air back into the system, which results in the overflow tank not doing its job and remaining full while the radiator level drops.
    #78 Patrick Wong, Sep 30, 2014
  19. HaroldW
    716
    95
    I took the black cover off and checked at the rad. . H
