  1. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Surprised to see my delivery from Japan on my doorstep when I got home. Couldn't wait to do some mods!
    Part # 08475-47030 - Rear bumper step guard, Carmate blind spot mirrors, Part #08471-00050-C0 - Rear multi-box.
    Got the JDM clean box (part # 08480-47050-C0), but didn't have time to install.
  2. ncases
    ncases Senior Member
    609
    672
    Chicago
    Recycled my polk standing speaker which i bought few years ago for my prius speakers. Zero cost = great sound system. Who needs a sub with these speakers? I have 2 lift so will be installing for the front soon. image.jpg image.jpg
    madmike23 likes this.
  3. xliderider
    xliderider Senior Member
    8,131
    3,268
    Honolulu, HI
    Good luck, car audio speakers are designed to withstand heat, humidity, and vibration, which home systems don't usually encounter. Also, there may be impedance differences between home and car speakers.
    SCH-I535
    ncases likes this.
  4. Grren4ever
    Grren4ever Active Member
    347
    167
    yes, be careful. most home speakers are 8 ohm I believe...and car speakers are 4 ohm. I'm not sure what this would do to the speaker in the long run. perhaps burn it out? But interesting to see how those polk speakers would sound in the prius !
  5. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Probably won't hurt the speaker, now the amp may be another issue.
    Grren4ever likes this.
  6. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    when we were wiring up the mirrors and had the door panels off I noticed the jbl's were riveted in! Why in the world would they do that? How do u even switch them if u ever wanted to.. drill the rivet out?Then how do u re install some others?
  7. Grren4ever
    347
    167
    Ideally, you gotta drill out the rivets and either fabricate a new speaker mounting plate, or a pre-manufactured one if you are doing a speaker swap.
    Beats the heck out of me why Toyota did this. My old 89 Honda civic was a breeze to swap out the speakers.
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Yes, u would have to drill out the rivets.to reinstall just use new rivets
  9. FrankB
    FrankB Member
    117
    53
    Increasing the speaker resistance from 4 to 8 ohm should result in less of a load to the amplifier drawing half the current.
  10. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Actually it is impedance , not resistance. Whole different ball game there.
    kenichols29 likes this.
  11. sfprankster
    sfprankster Active Member
    444
    490
    Santa Cruz Mountains, CA
    Get to test my own strength tomorrow on the interior light covers during a changeover to LED's.
    Beginning a pool as to how many covers I crack and/or break during the process. :cool:
    The real fun begins on Friday, with a scheduled delivery of a fog light system, to begin my Faux Five Project.
    ...and another pool for the number of broken clips when removing the front bumper cover. :rolleyes:
    #5211 sfprankster, Oct 1, 2014
  12. ncases
    609
    672
    Chicago
    Never thought about it. Thanks for the input.
  13. sfprankster
    444
    490
    First success, map light LED's installed in less than a minute without cracking or breaking the covers.
    ...except for the minor burn irritation from grabbing a HOT bulb with bare fingers. o_O
    Impressed with the amount of light emitted from the LED's.
    #5213 sfprankster, Oct 1, 2014
    ckam1989 and sfv41901 like this.
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Doh
  15. cheizy
    cheizy Member
    94
    129
    Los Angeles
    When you have the time sfv, can you post up how you did this? been itching to do this mod for awhile lol (y)
  16. Justdidit
    Justdidit LVNPZEV
    1,880
    710
    75
    Carrollton, Texas
    Four Touring
    Got my front license plate mounted finally. Used a eBay tow hook disassembled, sheet metal from Home Depot and a nylon spacer. Cut the spacer at an angle so the plate would line up with the shape of the bumper and bent the metal in a way that I could attach the license plate to the tow hook. Cost maybe a total of $25 vs some of the $50-80 retail versions. $15 tow hook, $6 sheet metal, $1 nylon spacer, $5 black paint and a handful of nuts and bolts.
    #5216 Justdidit, Oct 2, 2014
    C.R.E.A.M., ckam1989 and sfv41901 like this.
  17. sfprankster
    444
    490
    Had my Toyota dealer disable the Semi Truck Backup Simulator(reverse beeps) and change the setting to a single beep when placing the car into reverse. According to the service manager you can not completely disable this feature on a 2014. :cry:
    Time to get back to the interior LED conversion and more burned fingers.... :D
    Success!! Vanity LED's installed and not another burned finger or cracked/broken cover.
    #5217 sfprankster, Oct 2, 2014
    ckam1989 likes this.
  18. Grren4ever
    347
    167
    I bought some high quality (supposedly!) PIAA bulbs to replace my DRL high beam bulbs. These are yellow; so rumoured to be better for fog / inclement weather. I highly doubt it although IMO, it makes the car look a little different than every other car out there :). When spring and summer time rolls around, I will change back to OEM bulbs.
    The last time I purchased aftermarket "colored" bulbs for the car was over 10 years ago when I had my 89 civic. Right after the install, I turned on the headlights only to find that one had immediately exploded in the lens, ruining their reflective design (I made absolutely sure that there was no fingerprints on them before installing!). So this time, I went with a higher priced, higher quality product. No guarantees these won't blow but they are made in Japan. I was weary about buying the Nokya ones which are 4x cheaper.
    Now there is just one more mod to do on the Prius before I call it quits... :)
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Once a modder always a modder
    Chris S and Grren4ever like this.
  20. Grren4ever
    347
    167
    sfv41901: LOL...nothing practical left to mod. Home mortgage now needs a boost. Perhaps after my home has been paid off, I will start the modding again :)
