Where can I find hybrid battery charger
Discussion in 'Gen 2 Prius Technical Discussion' started by blue 04, Oct 4, 2014.
  1. blue 04
    blue 04 Junior Member
    26
    Huntsville Alabama
    I have found a complete Gen ll traction battery for sale out of a wrecked 08. I would like to buy it. Its been 8 weeks since the wreck. If I get it I need a way to keep it "alive" I'm not sure if its even still working now. Does anyone know of a reasonably priced charger I could get? Better yet possibly some other way to charge it? I'm considering taking the battery out of my 2004 and putting this one in but that's a lot of work. Thanks in advance for anything you can tell me
    Charles Ware
    Huntsville, Alabama
  2. vskid3
    vskid3 Active Member
    773
    228
    jeff652 likes this.
  3. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Check venice hybrid tech. They sale grid chargers
  4. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    You could build one. There's no hurry here. You want to trickle charge. A rate as low as C/100 would be more than enough. A small machine tool transformer, diode, and current limiting resistor could be put together cheap from internet components. This would be a high voltage dumb charger. You would have to supply the smarts. If you don't know exactly what you're doing the smartest move would be to buy a smart charger.
    No matter how you elect to charge please don't kill your self.
    Solerno likes this.
  5. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    Make sure you have a fan on the pack while charging and keep it in a cool place to avoid overheating the modules. The slower the charge the better.
  6. LEVE
    LEVE Member
    191
    97
    On the Willapa
    I picked a HV Traction battery grid charger up at:
    Venice Hybrid Tech
    It's on Ebay at:
    Ebay Grid Charger
    Since I've three Prii, I won't be without this little tool. I use it on both a Gen 1 and Gen 2 Prii to grid charge the traction batters. This is NOT a fix for bad modules/cells.
    Raj (Owner-Sale and Techie) is Excellent and I can't say enough good about his help on a project.
    JohnPrius3005 likes this.
  7. TampaPrius.com
    461
    300
    Tampa, Florida
    Great price on the charger but I believe the battery needs to be cooled whenever charging. If you use this charger you need to put power to your cooling fan or utilize and external fan. Despite the claims on the website, :
    "While I am not in favor of running the fan as the charger supplies only 350 mA of current and as such does not generate significant amount of heat but due to customers demand, I have now included the instructions and power source to run the fan while charging the Hybrid Battery for Honda insight."
    there is heat build up with 350mAh charging (I only have experience with genII Prius) . I used my grid charger out of the car one day w/o the fan and only charged for two hours. One hour later there was still hot air coming from the pack when I put a fan on it(ambient temp around 80F).
  8. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    I also bought the venice grid charger but I'll be hooking up an external fan.
  9. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Good to find someone else with this charger! I haven't installed mine yet (hopefully Wednesday) has yours worked well? Any tips or advice? Thanks
  10. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    I would generally recommend that you do some discharging on your packs as part of routine maintenance.
    And for future reference,
    The chargers/harnesses sold in the PriusChat store have discharge capability.
    The maker of the PriusChat store grid charger helped sponsor the PriusChat To Go Before, Prius owner event.
    Heck, they even gave away three chargers at the event. (Hybrid Automotive is the maker.)
    Also, don't forget, the ones you buy through Venice Hybrid do not support PriusChat in any way.
    The ones purchased through the PriusChat Store help keep PriusChat free for every one.
    TampaPrius.com likes this.
  11. LEVE
    LEVE Member
    191
    97
    On the Willapa
    Yes, it has worked well. I'll be using it on a spare battery that I purchased last week for my Gen II Prius. The install is straight forward. I secured the harness connection to the charger up under the trunk-lip near the left hinge. I sheathed the harness in split-loom, sometimes called convoluted tubing, and hid it behind the trunk carpeting. Bear in mind that there's full battery voltage on that harness. You don't the wiring to be hit/crushed or the end connector to get wet. That would not be a good thing. It's fused, but the harness is also long and could take a hit between the fuse and the battery. You must guard against that, hence the split-loom.
    I do like the idea of running the fan during the charging. That's something I'll have to look into! If it helps keep the battery temp low, then I'm all for it. I didn't even think about that.
    Aaron Vitolins likes this.
  12. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Thanks! Did you do the, charge 3 nights in a row for 10 hours? If so do you suggest me to do the same?
  13. LEVE
    LEVE Member
    191
    97
    On the Willapa
    No, I only charged one night, about 9 hours. The car had sat 7 months, no problems on start.
  14. wjtracy
    wjtracy Senior Member
    11,359
    3,606
    Northern VA (NoVA)
    The best idea, some feel, is to replace the Gen2 modules with Gen3 modules from a wreck.
    So I am not sure I would be speculatively buying a used Gen2 wreck HV battery, if I understand correcty, that you have no immediate use for.
  15. TampaPrius.com
    461
    300
    Tampa, Florida
    Here is a homemade grid charger that one of my customers made.
  16. wjtracy
    11,359
    3,606
    Northern VA (NoVA)
    ...without understanding much about what I am looking at, but, alligator clips?
  17. blue 04
    26
    Huntsville Alabama
    He, I finally got the Venice grid charger. I'm excited and wanted to use it but there are no instructions In the box. No one at Venice answers my call to either number and no email response. Did you get instructions?
  18. bisco
    51,040
    what is it, chinese?
    m.wynn and Britprius like this.
  19. Aaron Vitolins
    1,612
    1,144
    Franklin TN
  20. bisco
    51,040
    cali with no instructions and no one to answer the phone? worse than china, north korea?
