Immobilizer not letting the car start after trans swap
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cardana24, Oct 5, 2014.
  1. cardana24
    cardana24 Junior Member
    91
    Charlottesville, VA
    Hey guys,
    I have an 06 Prius. I bought it with a broken/leaking transmission about 3 months ago. I drove the car home and it sat for a few months, then I drove it into my garage to start working on it a few weeks ago. I just finished up with the trans swap this evening and I went to "start" the car to get the coolant circulating/blead, and the car would not start. I get nothing, I just get a blinking red light in the shape of a car with a key in the center. I am pretty sure this is the immobilizer symbol. What can I do to reset/fix this? This is my first prius and I have not driven this one more than 50 miles so it could be something silly that I am just not familiar with. This is what I am doing...I get in the car, put the key in the key slot, and I push the brake, then I hit the power button...I get nothing, other than the blinking light on the dash. Any help guys?
    okay, a little more information. I went back out to the car and messed around a little bit. When I put the key in the slot I get what I described above...nothing. But if I don't put the key in the slot, and just push the power button the display comes on but I am not able to shift into any thing other than park or neutral. When I am able to power up with out the key in the slot I get a red car with an explanation point going through it at the top left of the screen. Then at the display just below the windshield most of the lights stay lit up. What does this point towards? Why would the car not try to go into Drive or Reverse? And what's going on with my key? The only two times I have driven this car i just put the key in the slot and it turned right on and I drove away, now with the key in it will not do anything.
    #1 cardana24, Oct 5, 2014
  2. JC91006
    JC91006 Senior Member
    16,723
    8,546
    The hv battery interlock switch is not locked into place. Insert the interlock switch, pivot up 90 degrees and push downward to lock it.
  3. cardana24
    91
    Charlottesville, VA
    Is that what they refer to as the service plug grip? Like I said this is my first time working on a prius so I am not super familiar with everything yet.
    *edit*
    I just watched a youtube video on removing and installing the service plug...you are right, I did not push it down to lock it into place. I only rotated it up 90 degrees and assumed that was fully installed. I'll try locking it into place when I get home today. Thanks for the tip!
  4. cardana24
    91
    Charlottesville, VA
    Okay, I pushed the service plug down and I get no change. When I put the key in the slot it does nothing different...should it?
    Where is the imobolizer module held? I also replaced my driver side front and rear doors while the car has been down. I would not assu
    E anything important would be in them. Any ideas?
  5. JC91006
    16,723
    8,546
    Did you verify your 12v battery is good?
    Changing the doors has no effect on the car starting.
  6. CARspec
    CARspec Junior Member
    53
    Eden Prairie, MN
    2014 Prius Plug-in
    You, sir, get the cajones award for most courage. You went from "first time working on a prius" to one of the most challenging jobs in one step. Good for you (check all your connectors, even the best of us leave some unhooked)
  7. cardana24
    91
    Charlottesville, VA
    The battery had enough power to drive the car into the garage two weeks ago, and I charged it before I tried to start the car, so I assume its fine. Plus my overhead lights work, my headlights turn on and look fine...I think the 12v battery is good, but no I have not had it tested.
    Thanks man, it was a pain in the A$$ mostly because of how heavy the trans is. I hooked it up to my engine hoist at the upper mount point and pulled it up from the floor, but that would make it tip towards the engine, so I had to use a jack on the leading edge of the trans, it was a real pain, I took me hours to get it lined up by myself. Another thing that was a pain was the sub frame needing to be removed...lame...oh and to top it off having to take the windshield wipers off to do anything...what in the world!! Anyway I'm not a mechanic, but I do work on cars a lot, I do engine and trans swaps regularly, I did like the fact that the cvt bolts together like a manual transmission, but it was still a royal pain for the first time.
    When putting things back together I did notice that I did damage the connector that goes to the black connector on the firewall side of the trans. What is that one for? I don't think it is that messed up but I did notice that I smashed some of the wiring on that one.
    The car is acting like it does not recognize the key when it is put in the slot...it does nothing, and it actually does less than when using it as a smart key. When it's used as a smart key the power will turn on, but it will on shift into Park or Neutral. It does not even try to go into drive or reverse. And all of the lights are lit up on the dash board (i.e. brake light, CEL, red triangle, maint required, etc.)
    When I close all of the doors and lock them with the key fob the immobilizer light burns solid, but if I unlock the car it blinks constantly (about once every 3 seconds) even when I have the key in the slot.
    I really don't know what else to try at this point...
  8. CARspec
    53
    Eden Prairie, MN
    2014 Prius Plug-in
    The harnesses running around and about the transaxle do so many things it is hard to say exactly what you may have broken. In my professional experience, taking a few hours off from the job helps you clear your head and make progress when you come back. Chill out, then come back fresh with a plan and you'll make progress.
    Worst case you pay for the tow to a good shop/dealer and some diagnostics and spend a bit of your DIY savings. Good luck!
  9. JC91006
    16,723
    8,546
    Do a complete reset of the car. Since the key slot is not working properly, don't use it for now.
    1. Make sure the interlock switch is locked in place again.
    2. Disconnect the 12v battery negative terminal for a few seconds.
    3. Try to restart using the smart key function,no slot. While your foot is on the brake, push the start button. You may have to push the start button twice.
  10. cardana24
    91
    Charlottesville, VA
    I will try that, but what is the interlock switch? I have already tried steps 2 and 3 but I am not sure what the interlock switch is.
    Is a "complete reset" just unhooking the battery for a little while?
  11. valde3
    valde3 Senior Member
    2,002
    747
    Finland
    Interlock switch is service plug.
    Yes disconnecting 12V for long enough will reset everything. If it still doesn’t do anything you probably left something major disconnected.
  12. cardana24
    91
    Charlottesville, VA
    Resetting did not change anything.
  13. CARspec
    53
    Eden Prairie, MN
    2014 Prius Plug-in
    It sounds like you have something disconnected or damaged something during the swap. Sorry :/
  14. cardana24
    91
    Charlottesville, VA
    I am going to see if I can make sure that plug on the back side of the trans is plugged all the way in (the one I mentioned I damaged earlier).
    Since I am new to prius I want to make sure I understand how a cold start up should work. When you first power the car on the ICE should start up for a little bit correct?
    Here area few pictures I took. These two pictures show all of the dash lights lit up like I was talking about. When the key is inserted into the slot none of this happens, this only happens when I use the key as a smart key.
    See the car with the exclamation point on it in the top left
    and here are all of the lights that come on
    And here is the black plug that goes in the black female plug on the fire wall side of the trans that I messed up
    #14 cardana24, Oct 8, 2014
  15. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    The lights show that there is a fault code present, and the ready light on the dash is not alight. The engine should start after about 7 seconds of the ready light coming on. A Prius aware code scanner is needed to give you guidance of where the fault lies.
    I suggest investing in a Mini VCI from Amazon or Ebay at around $25 for use with an old XP laptop. This is the best investment you can make if you have and wish to work on a Prius.
    John (Britprius)
  16. cardana24
    91
    Charlottesville, VA
    Thanks for the input. I just ordered this one New MINI VCI for TOYOTA TIS Techstream V9.30.002 16Pin Cable
    It looks like it is the newest update, now I just need to figure out if I have a laptop with xp on it.
  17. Britprius
    5,194
    1,921
    It does not have to be XP any windows 32 bit system will work with it. Windows 7 and 8 will work, but takes a little more time and effort. The VCI will work on any Toyota or Lexus reading all ECU's, engine transmission, battery, steering, air bags, brakes, abs/vsc and body with sub codes and issuing likely problems. It will also give emissions related codes "engine" for most other vehicles.
    Mac systems will run it with "Boot camp"
    John (Britprius)
    usnavystgc likes this.
  18. cardana24
    91
    Charlottesville, VA
    while I am waiting on this special cord to come in, will an OBDII scanner shed any light on what's going on? I have an OBDII scanner I just need to find it. Also how do you scan a prius with a regular OBDII scanner? With a "normal" car you turn the key to on, but not run when you are scanning for codes...how do you do it on the Prius?
  19. valde3
    2,002
    747
    Finland
    Generic OBD2-scanner will only read engine fault codes. And your problem is more likely hybrid system problem.
    Pushing power two times without pressing brake pedal will put Prius into ig-on mode (everything except hybrid system is on (12V battery will drain)) where scanning should be done.
  20. cardana24
    91
    Charlottesville, VA
    I picked up another plug for the transmission today to replace the one that I smashed (pictured earlier in the thread) just to rule that out. I will be pulling the inverter back out this weekend to check all of the connections and replace that plug. Will report back.
