c1310 c1259 after HV battery cell replacement 2005 prius
Discussion in 'Newbie Forum' started by chanel1313, Oct 7, 2014.
  1. chanel1313
    chanel1313 New Member
    United States
    C1259 hv system regeneration malfuction
    and c1310 malfunction in hv system codes showing after i replaced 2 cells on the hv battery. Screen shows the hv battery does charge while driving, gets full green bars, however it discharges quickly and the electric part of the engine never kicks in, the car only drives with the gas engine. At a loss here. Help??
    52,006
    what did you use to read the codes?
  3. chanel1313
    United States
    Scan gauge II
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,441
    3,332
    Madison, Wisconsin
    Does unhooking the 12v battery for 30 seconds clear the codes?
  5. chanel1313
    United States
    No it doesnt. I also recently replaced the 12v as well.
  6. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    Are you 100% sure you correctly inserted the orange service plug.
    It is a 3 step process
    1) Insert orange plug into battery pack
    2) rotate handle upwards
    3) slide orange handle straight down until you hear it click in place
    Step three is the one most often missed.
    Go in back right now and go through 3 steps.
    Not 1 step. Not 2 steps. 3 steps!
    edit: Also, double check that all computer harnesses are fully engaged.
    #6 ericbecky, Oct 8, 2014
  7. chanel1313
    United States
    Yes everything is in place properly
  8. ericbecky
    4,441
    3,332
    Madison, Wisconsin
    I would get a scanner where you can see live data to discover the problem.
    Especially HV ECU info.
    You saved money on buying a battery.
    Put some of that money towards a better scanner.
    Your going to need/want it for future repairs you will be doing to the pack.
    Feel free to call me and chat.
  9. chanel1313
    United States
    Is there one youd recommend? I ive seen another recommended on here, i think its called The mini scan vac?
