Difference between radio with/without CD player
Discussion in 'Gen 3 Prius Audio and Electronics' started by AllenZ, Oct 2, 2014.
  1. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    I have the basic II and my teen daughter who has sharp ears told me the sound is not good on radio.
    Now I have a chance to buy a radio with CD from someone who upgraded to Nav radio.
    Do you experience significant difference on sound quality? Does those two versions use the same speaker?
    I don't really play CD, so if sound quality is same then I will pass.
    Thank you!
    Allen
  2. situationalawareness
    83
    43
    San Tan Valley, AZ
    Just plugging in that other stereo isn't going to give you any better sound through the same speakers, with radio stations. That part I can tell you without any other information.
    AllenZ likes this.
  3. AllenZ
    640
    63
    Chicago
    Thank you!
    So the speaker does play a role in the case of Prius?
  4. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    You would have to buy a new radio and new speakers. The sound is pretty poor in a prius unless you upgrade.
  5. situationalawareness
    83
    43
    San Tan Valley, AZ
    In almost all cars, the speaker is what plays most of the role. Stereos don't really push out much, and depending on how much goodness is wanted from the sound I'm sure an amplifier or some other in-line utility is needed.
    Personally, I'm through with those years. I have a Persona and the system is plenty fine for me. However, yes, if you want better sound then the easiest way to do it is new speakers, and if more power through those speakers are wanted then an amp.
  6. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved to the audio subforum
