Flexible Solar Panels on roof?more MPG?
Discussion in 'Prius c Accessories and Modifications' started by formula, Oct 10, 2014.
  1. formula
    formula Member
    320
    32
    CA
  2. GregP507
    GregP507 Senior Member
    3,002
    481
    We did the math on this idea in a previous thread awhile back. It's not going to make much of a difference most of the time, but I thought it was worthwhile for the benefit it provides, albeit small.
  3. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    ...my thought was maybe one use of solar for MPG would be to heat up engine block overnite.
    I have some spare solar panels, so I was thinking charge a battery in the garage and have a lower wattage heat source come on under the car at a set time. Of course you are in CA but maybe warmer engine helps. The other thing I think about is heating car inside so its warmer inside, again thinking cooler climates. I'm going think about doing some of those things this winter, and measuring temps with and without to see if it helps at all.
    It's whole nother issue if I actually do it, Iam just thinking about it.
  4. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    These are 12 volt panels, which would charge the aux battery. Working out some 220 volt panels to charge the HV battery would be interesting. The higher voltage panels are available as they are used in direct, back-fed line charging. The cost analysis is, no doubt, not favorable. That is called a hobby....
  5. ElwoodParisien
    ElwoodParisien New Member
    2012 Prius Alpha
    Not sure these panels are effective or not.. I think they are bit expensive with little efficiency..
  6. bisco
    51,901
    they work great for those solar racers, maybe they have different voltage motors?
