Electrical connection behind bumper grille
Discussion in 'Gen 2 Prius Technical Discussion' started by lo21212, Oct 20, 2014.
  1. lo21212
    lo21212 Junior Member
    Hello everyone, two nights ago while driving at night I unfortunately hit a small animal. When I looked at the front of my car the next morning i realized the bumper grill was broken but behind where the grill was was an electrical connection which I have never noticed before. It is hanging down right in the middle. Now the lights work fine and I have not had any warnings. Does anyone know what that connection is for?
    thanks
  2. Mutual
    Mutual Junior Member
    The only electrical connection in front of the condenser is the horn. There are two horns, check if one of them is loose.
  3. lo21212
    Where would I find the horn and the connections? Is it on top of the grill so I need to open the hood and remove the plastic cover towards the front of the hood?
  4. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    That connection is the sensor for the outside air temperature on the MFD. It also supplies air temperature information to the engine ECU. That unit is normally fastened to the upright steel rail in the picture.
    John (Britprius)
    Data Daedalus likes this.
  5. lo21212
    Thanks John, does it clip to it somehow? So it is not a connection just a sensor?
    Thanks a bunch, I always have a fear that my car will explode
  6. Britprius
    5,194
    1,922
    I believe it just clips to the rail from memory, and as you suggest it is just a sensor with no ongoing connections. No explsosions:eek:
    John (Britprius)
  7. Britprius
    5,194
    1,922
    It looks from your picture you have damage to your AC condenser. Try running your AC to confirm if you have a refrigerant leak or not.
    John (Britprius)
