  1. sfprankster
    sfprankster Active Member
    444
    490
    Santa Cruz Mountains, CA
    The vinyl cutting was as simple as it gets. I used a Mason jar wide mouth lid for the circular pattern and cut around it with a sharp hobby knife. Measured the approximate length I wanted the cutoffs with a ruler, cut the edges off the vinyl circles and applied them to the lens. Total time from start to finish, less than 20 minutes. The vinyl I've had around for a while after wrapping my Civic's dash.
  2. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Military style blackout light. The possible inspiration for the fog light mod post earlier.
  3. sfprankster
    444
    490
    It was the image below(LED fog light for a Prius v on Amazon) that got the smoke coming out of my ears.
  4. xliderider
    xliderider Senior Member
    8,130
    3,266
    Honolulu, HI
    Or the light bulb over your head. ;)
    SCH-I535
  5. xliderider
    8,130
    3,266
    Honolulu, HI
    Didn't you find that the oem foglight lenses are oval shaped rather than round though? They are wider than they are tall.
    Seems it would be much easier to mask a horizontal section on the lenses, then apply several coats of Plastidip. I could even match the foglight shrouds to the foglight masking color. :)
    SCH-I535
  6. sfprankster
    444
    490
    I used what I had available here at home.
    The shape of the lens is closer to circular on the set I have installed, with a slightly convex lens shape. The jar lid I used as a template, is larger than the lens dimensions by 3/16", so the excess vinyl material stretched easily into the recessed edges, after running the fog lights a few minutes to warm the lens.
    Spraying with Plastidip, near the lower grill area, would be a nightmare for me to remove the overspray. Having a case of OCD, I would go nuts just masking the area. It took me a total of 20 minutes to locate the tools, materials and complete the project. Getting a can of Plastidip would be a 20-25 minute drive off the mountain, just to begin the project. :)
    Truthfully, who's going to notice the difference between vinyl and Plastidip when this is approaching? :cool:
  7. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    Yea I hear Ya know the OCD. I wrapped my fog lights with lens vynal and used a jar lid and anything else I thought was the size of the lens. It was still a nightmare to put on with out taking the fogs off the car to cover the whole light like I wanted. Once I did them I still wasent satisfied because I had a few wrinkles because the lens isn't flat. So I went to a friend's house and put the car in his lift and took the fogs off and did Alot of pulling and stretching on the lense vynal to keep it wrinkle free!
  8. sfprankster
    444
    490
    I began the conversion to turn signal LED's, from VLEDS, with the addition of an electronic LED flasher and converted the rear turn signals to platinum amber LED's(yeah, I know, do the easy ones first). :) The changing of the flasher unit took more time than I expected, so the front turn signals will have to wait until another day when I have more time.
    Stock halogen:
    Platinum amber LED:
  9. zombiegristle
    zombiegristle Junior Member
    I installed the shark fin antenna, and finally put gas in the car. $27 got me 485 miles. This is the coolest thing ever.
    I'll take some pictures when it's not 8PM and pitch black outside.
  10. Sean Callahan
    Sean Callahan Senior Member
    314
    582
    Honolulu
    Google some prius driving tips, may help get more mpg :) I live in Hawaii so it's a little more expensive more like 37$ to fill up here. But my driving range is 540-560 miles to a tank.
    zombiegristle likes this.
  11. zombiegristle
    Thanks, will do - I've been getting used to the ECO mode and using the HUD for feedback, but most of my driving is freeway so I'm not sure how high I can reasonably expect the mileage to get. My other vehicle is an old station wagon and filling up is closer to $70 every 300 miles!
  12. Sean Callahan
    314
    582
    Honolulu
    Yeah I run in Eco mode all the time. Best way to go from what I hear.
  13. Heresjohnnee
    Heresjohnnee Junior Member
    56
    St. Louis
    LOVE these. Can you provide any info on the kit? Did the small square lights come along with the bigger ones in the fog light location? Cost? Easy enough for someone without automotive wiring experience to do on their own? Looking good.
  14. Cezarcaz
    Cezarcaz Member
    102
    49
    Chino
    Quick and cheap center caps
    ImageUploadedByTapatalk1414016566.897049.jpg ImageUploadedByTapatalk1414016585.156630.jpg
    Jeromy likes this.
  15. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    I like the white ones.
    Was that in the store or on their website? What is the make of it?
    #5395 DaneH5, Oct 22, 2014
  16. munkeeboi
    munkeeboi Active Member
    100
    173
    go to the walmart.com and search for blind spot mirror. $4.95 . just ordered mine :)
    Some stores may have them but you can check on the website
    kenichols29 likes this.
  17. ncases
    ncases Senior Member
    609
    672
    Chicago
    I bought it from the store.
  18. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    Found something some of you might be interested in. Toyota will create a badge for your car for free. See link for details. Ordered one for Plus IV.
    Toyota more than a car.
    PlusIV
    #5398 Plus IV, Oct 24, 2014
    Burna J and RightOnTime like this.
  19. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    They are two different sets of lights. The fog light kit cost about $300. The two square drl's cost about $100. Wiring is simple you can refer to several threads here.
    Jeromy likes this.
  20. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
