How long would it take to drive to the sun?
Discussion in 'Fred's House of Pancakes' started by GregP507, Oct 24, 2014.
  1. GregP507
    GregP507 Senior Member
    3,002
    481
    93,000,000 miles/65mph= 1,430,769 hours to reach the sun.
    1,430,769/24hrs= 59,617 days to reach the sun.
    59,617/365days= 163.3342 years to reach the sun.
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    But remember that this is an average number. The Earth actually follows an elliptical path around the Sun. At the closest point of its orbit, called perihelion, the Earth is only 91.40 million miles. And then when it’s out at the most distant point of its orbit, called aphelion, the Earth reaches 94.51 million miles.
  3. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Well the nice thing is in space there's no speed limit (except for the speed of light perhaps) so I'd want to drive a bit faster than 65mph :p
    The Apollo spacecraft hit 24,000+ mph, so it would only take 160 days at that velocity.
  4. amm0bob
    amm0bob Permanently Junior...
    7,730
    2,547
    Neither one of y'all are pilots huh...
    Ummmmm... the Sun is also moving through the Milky Way at over 50,000 mph... if you drive to where it is now you will miss it when you think you should get there...
    Ya gots ta put a little lead in your shot, like hunting a dove, if you shoot where you see it you will miss it... you have to shoot in front of where it is going to hit it at all.
  5. GregP507
    3,002
    481
    But it would be hell on the brakes when you got there...
    #5 GregP507, Oct 24, 2014
  6. Mendel Leisk
    40,497
    A little more down to earth:
    384400 km's to the moon
    At 100 km, 24 hrs per day
    Takes you: 160 days, and a bit.
  7. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    To make sure you don't burn up - go at night. :p
    Ashlem, GrumpyCabbie, amm0bob and 2 others like this.
  8. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    You get better mileage is you drive a little slower. Also driving to the sun is very inefficient because the closer you get the more you'll want your A/C and that'll just drain the heck out of your battery.
  9. xpcman
    1,302
    295
    Well so are you when you leave Earth and after you are in space. Your not an astronaut.
  10. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    163 years? That's a lot of bathroom breaks...maybe a solar sail would speed the journey?
  11. orenji
    orenji Senior Member
    5,886
    3,487
    Why drive to the sun, you can melt in Arizona and have gas left over!
    KK6PD and xliderider like this.
  12. bwilson4web
    15,991
    Ok, this is a job for NASA-miler:
    1. Pulse to the moon
    2. Glide to the moon
    3. Gravity pulse to increase speed
    4. Glide to Earth
    5. Gravity pulse to increase speed (a second moon pulse is possible)
    6. Glide to Venus
    7. Gravity pulse to increase speed
    8. Glide to Mars
    9. Gravity pulse to increase speed
    10. Glide to Sun
    Ashlem, Chuck. and fuzzy1 like this.
  13. fuzzy1
    10,335
    With no air drag after the first few dozen miles, and a downhill coast once out of the earth's gravity well, I also don't see any reason to ride the brakes to keep the speed down to 65.
    1. It seems that very few folks realize that a direct flight to the Sun, without these gravity assists, is about the most costly (in fuel) mission we can do inside the solar system. It actually requires far far more fuel than a direct flight to Pluto, the Kuiper Belt, or even a complete escape from the Sun. The P&G path you list doesn't save just a moderate fraction like we'd get on the road, it can save an enormous fraction.
  14. Mendel Leisk
    40,497
    Who let the realists in..., this thread was doing just fine. :p
  15. bwilson4web
    15,991
    Well I did make one mistake as I should have suggested pulsing to Mercury. But if we pulse to Mars, we have the option of including more pulses:
    • Moon pulse
    • Earth pulse
    • Venus pulse
    • Mercury pulse
    I just didn't have my handy-dandy, NASA orbital calculator handy. In truth, each alternative needs to be examined carefully as planetary and moon alignment are date specific. As the number of pulse events increases, the available start windows change, generally moving further in the future. A moon-earth pulse path has the more immediate start window but the least velocity increase. Every additional pulse added increases the velocity at the risk of a narrower start window.
  16. fuzzy1
    10,335
    No Jupiter pulses in there? I thought that had to be used for the biggest delta-Vs, such as the Ulysses probe.
  17. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    Even better than pulse and glide -
    Just "Set the Controls for the Heart of the Sun"*
    * Pink Floyd
    hyo silver and bwilson4web like this.
  18. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    Unlike some people on this thread, I'm not a rocket scientist. But.....
    Wouldn't it make sense to just fire your rockets backwards along Earth's orbit? Once you've lost the centripetal force, you could just fall into the sun's gravity well.
    The Earth is orbiting the sun at - what? - 67,000mph or something. If Apollo could get up to 24,000mph, then if you did that going backwards along Earth's orbit, you'd drop your orbiting speed to 43,000mph, which wouldn't be enough to keep you in orbit. So just the one burst of power to head away from the Earth at 24,000mph and you should be able to coast the rest of the way.
    Or am I wrong?
  19. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    Also, I have enough trouble getting traction when pulling away from an uphill junction on wet leaves. I'd imagine a vacuum and microgravity will send the traction control completely nuts, and I'll never actually get up to 65mph.
  20. bwilson4web
    15,991
    Each gravity-assist pulse in theory can add twice the planetary velocity to the space-Prius. But in reality the gains are less but impressive:
    ps. I do not endorse 'games' but calling this a simulation exercise gives a clue: Kerbal Space Program
    #20 bwilson4web, Oct 26, 2014
    hkmb likes this.
