Alignment at Dealership
Discussion in 'Gen 2 Prius Main Forum' started by PriusGuy32, Nov 7, 2014.
  1. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Did I just get ripped off?
    I had a coupon for $79.95 for a 4-wheel alignment, which included a tire rotation. I noticed my tires were wearing unevenly (specifically the fronts) and my steering wheel was off-centered. But, looking at the numbers, it looks like they only adjusted the toe.
    Im thinking, in a perfect world, I should've paid for a front end alignment and not a 4-wheel one. Just sayin'
    #1 PriusGuy32, Nov 7, 2014
  2. JC91006
    JC91006 Senior Member
    16,761
    8,562
    You can't feel ripped off if you got what you went to the dealer to get. What are they suppose to do? Say no to your service request?
  3. PriusGuy32
    1,417
    514
    Well, actually... I have had an experience before where I brought my vehicle in for service, and the shop informed me that the work wasnt necessary.
    I guess when I think 4 wheel alignment, but all they adjusted was the front 2 tires, shouldnt I have just been charged for a 2-wheel alignment?? lol
  4. JC91006
    16,761
    8,562
    There's probably no reason to get a 4 wheel alignment, the rear wheels don't go off track. It just goes straight. I normally opt for the 2 wheel alignment if the option is there. My mechanic is pretty sneaky, only has 4 wheel alignments and nothing else.
    PriusGuy32 likes this.
  5. PriusGuy32
    1,417
    514
    Does the toe in/out significantly affect mpgs?
  6. bisco
    51,835
    you can't adjust the rear wheels on a prius. if there is an issue, you have to go to a specialty shop that can install shim kits. the dealer isn't even going to look at them. that's probably a generic coupon for all cars. they do the same thing with the 12 volt battery, then when you show up in a prius, they're like, oh no, it doesn't apply to the prius battery.
  7. bisco
    51,835
    some say it does, but there is no clinical evidence.
  8. valde3
    valde3 Senior Member
    2,002
    749
    Finland
    Its 4-wheel alignment if they check all 4 wheels. Rear ones on Prius (and many other modern cars) are only adjustable by replacing rear axle. Or using shims witch manufacturer is against.
  9. bisco
    51,835
    that would be a front end alignment, and a rear end inspection.:p
  10. PriusGuy32
    1,417
    514
    Geez, all that and I didnt even get a kiss on the cheek before I left the dealer! :LOL::LOL:
    I want to add that my steering wheel was off center from when the dealer performed the steering bolt recall - I brought it back twice and they tried to straighten it out each time, but the wheel was still 5-10 degrees off center to the right. :mad:
    OH, and one more thing - do any of those numbers look out of whack or is my Prius in pretty good shape still? I ask because Ive heard about the shims, etc.
  11. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Well that's just not the way it works......everywhere.
    You are paying for the alignment CHECK; adjustments are free. :)
  12. PriusGuy32
    1,417
    514
    Wishful thinking on my behalf I guess :D
