My 2010 Prius IV has fog lights but no switch on the light/turn signal lever. Did Toyota put them in instead of using a blank. The accessory list shows fog lights on the V only. Would they work if I had a different control lever installed?
The 4 doesn't have factory installed foglights. Are you sure you have them? I have a 2011 4 that didn't come with foglights. I installed them later. SCH-I535
Did you get this vehicle pre owned? Look for a foglight switch on the lower left side of the dashboard, near the dashboard illumination brightness rheostat wheel. SCH-I535
