Frozen Washer Fluid line causing possible problems
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jonny Zero, Nov 13, 2014.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Is anyone concerned that the long line going to the rear washer gets frozen and breaks and spring a leak into the headliner or am I worrying about nothing?
    51,040
    washer fluid doesn't freeze. after 10 years of pri, i'd say nothing to worry about.(y)
  3. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    Believe it or not, I recently saw washer fluid for sale at a local gas station that was good down to +32 degrees!!! Wth???
    (I guess they were trying to get rid of their Summer fluid)
    #3 RRxing, Nov 14, 2014
    GrumpyCabbie likes this.
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Water will freeze. Correct washer fluid will freeze at lower temperatures than water alone. The cheap stuff is barely better than water and the good stuff is expensive but worth every penny when you need to use your washers in very cold weather.
  5. john1701a
    john1701a Prius Guru
    12,794
    5,276
    57
    No concern whatsoever. I bought a gallon of the -25°F rated stuff for $2.99 last night. It's no big deal.
    -8C (18F) on this morning's commute. That will be considered warm here in 2 months.
  6. Mendel Leisk
    40,495
    Wait a sec, you're in Texas?? Maybe someone from the northern central US, Canadian Prairies, or Finland will weigh in, but I think you're fine.
    Personally I just use the anti-freeze type, year 'round. Not really 'cause it super cold here (it isn't), but because I know the stuff I put in in the spring is likely still there by the dead of winter.
    Ouch, just checked: it's -6C here right now, unusual cold snap for us.
    They were mowing lawns here, a week back. :ROFLMAO:
  7. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    The line is soft and of a small diameter. Is will just expand and contract with the frozen liquid.
    I am certain Toyota's engineers tested this with their cold soak tests, they are not stupid or negligent.
  8. Mike500
    Mike500 Senior Member
    2,593
    766
    The high performance RainX stuff is cheap at $5 for a box of two gallons at WalMart.
    Why buy the really cheap stuff?
  9. RRxing
    2,530
    1,806
    NEPA
    So, the only time you clean your windshield is when it rains? :p
    #9 RRxing, Nov 14, 2014
  10. bisco
    51,040
    i mowed my lawn wednesday, and shoveled my driveway this morning.:mad:
  11. Mendel Leisk
    40,495
    Pretty much. I don't much use the washer fluid when the car's dry, ends up a sorry, splattered mess. Gets me thinking it's time to wash it again, if it comes to that.
    But yeah, the reservoir takes about a gallon, might barely go through a pint in the summer, wouldn't want summer fluid hanging around through winter.
  12. john1701a
    12,794
    5,276
    57
    What is the point of a "summer" fluid?
    The all-season stuff I just bought covers the entire temp range for $3 and has worked great.
    [​IMG] . [​IMG]
    Okinawa likes this.
  13. Mendel Leisk
    40,495
    I wonder the same thing. I guess it makes sense in the tropics.
    I go a little over the top, get the Toyota Washer fluid, even it's only $3.95 for 4 liters. Good to -40C, though that rating can be pretty BS: they all seem to freeze on the glass, just a few degrees below freezing.
  14. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    The problem with the winter fluid is that it is illegal to sell most of the year around here because of the VOC content. A lot of times we have hardfreezes before the stores are legally allowed to stock the 0#F stuff and we are caught with our pants down. I don't want to be a hoarder but I might have to.
  15. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    That's what I do. The first cold snap and all the shops sell out of washer fluid. Easy solution is to store it from the year before.
  16. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    That is normal !
    The rating only means it will not freeze in the washer fluid reservoir !!!
    IT WILL freeze on the glass ! The stuff (which prevents it from freezing) evaporates quickly wind helps to freeze on the glass.
  17. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Don't think I've ever seen freeze damage to a windshield washer system (and my dad used to dilute the stufff 50/50).
  18. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    I went by a WalMart today and found 6 gallons of the 0*F stuff tucked behind a bunch of +32*F summer formula bottles. The packagings look alike so it's likely they mixed them up in there. I don't think it is legal for them to stock them yet. But I was able to check out so scored!
    Last night we set a record over night low of 25*F here in Austin.
    I have had 0*F fluid icing up on the windshield when it is 22*F out.
    #18 Jonny Zero, Nov 14, 2014
  19. Okinawa
    Okinawa Senior Member
    1,333
    317
    A friend of mine recently sent me some pics of a mountain of snow in Minnesota last winter. I admire you people up there. You can handle it.
  20. Mike500
    2,593
    766
    That sounds strange for Texas, which has some of the most laxed environmental regulations for chemical industries.
    A very simple and easy solution is to go to Walmart and purchase a small yellow bottle of Heet. It contains isopropyl alcohol which is fully mixes with water. It is the alcohol concentration in the washer anti-freeze that keeps it from freezing.
    After you put it in, be sure to operate the rear washer to replace the current fluid with the NEW.
    If you can't find "isopropyl" HEET, rubbing alcohol with isopropyl from the local drug store will work the same, but it is more diluted.
    #20 Mike500, Nov 14, 2014
    Andyprius1 likes this.
