What type of oil...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Virg, Nov 20, 2014.
  1. Virg
    Virg Junior Member
    28
    Austin Texas
    What type of oil is provided by the dealer in the first two free services? Is it 0-20 synthetic or some other?
    Or do you ask for an oil upgrade.
  2. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    Toyota 0-20 synthetic is what my local dealer installs for the two free oil changes covered under Toyota Care
  3. Mendel Leisk
    40,495
    Toyota's oil is all I've ever used. I believe it's the oil they use if the customer doesn't ask for anything else. When we went to an new owners open house they had the stuff set out in graduated pitchers, said it was Toyota oil. Pretty clueless, but I've read it's a good oil. At $5.65 (Can) per liter it works for me.
  4. bisco
    51,040
    probably the stuff they drained out of the last guys car.
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    You wish. It is old frying oil from Mickey D's.
  6. yeldogt
    yeldogt Active Member
    810
    313
    NE
    I believe the Toyota is a blend .. my bottle was.
  7. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    They should be putting in 0W-20, but they may try to use 5W-30. Be sure to ask and ensure they put in the synthetic oil type spelled out on the fill cap (0W-20.) The dealer put 5W-30 in on one of my early visits, and I had them change it again using 0W-20. I've changed my own oil since then using Toyota's 0W-20.
