Are there any softer springs for the Prius?
Discussion in 'Gen 2 Prius Main Forum' started by yibo829, Dec 6, 2014.
  1. yibo829
    yibo829 Junior Member
    84
    I'm getting the front struts replaced under extended warranty next week, so I'm wondering if there are options for softer coil springs for my car. So far I haven't found any online, but I wonder if springs from other cars like the Avalon may be able to fit the struts on my car. I don't know.
    My main goal is to achieve a softer ride and I figure this is a good opportunity to change the springs if that'll help me achieve that goal.
    Thanks for your help.
    This is a 2009 Non touring Prius.
  2. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    softer, quieter ride would be quite nice
  3. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    As far as I know, there isn't any options. You could look for a soft quiet tire though, it will make a difference. It will also take down your mpg :/
  4. yibo829
    84
    I had a feeling there aren't any options. I will look at softer tires when my current energy savers wear out.
  5. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Does your car have the base 15" wheels?
  6. yibo829
    84
    Yes i do have the 15 inch wheels.
  7. Patrick Wong
    18,210
    6,510
    Use the recommended tire inflation pressure of 35/33 psi (as opposed to using a higher value.) Your tires will wear unevenly (shoulders will wear faster) but the ride will be a bit softer.
  8. Tresguey
    Tresguey New Member
    If it were me I would call QA1. Tell them what you want to achieve. Or call Summit Racing, they have a well trained staff and if they don't know what springs or struts to use they will have a contact at a manufacture that does.
    I am a Sales Manager of a aftermarket parts manufacture. I usually will have a contact to just about anything on a car and if I don't Summit Racing will be my next call.
