HV Battery Fan Running Higher Then Normal On FWY
Discussion in 'Prius c Technical Discussion' started by priusCpilot, Oct 7, 2014.
  1. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    Recently installed a curt trailer light. I modified the V plug in harness to work with the C.
    I noticed the fan was running louder then usual. I took the right rear panel off were the HV exhaust vent it and there is no ducting from the factory.
    The battery duct just goes to the back of the seat and vents out in that right corner right behind the 12V.
    It makes its way up and over the right rear tire tub then what ever comes out of the rear exhaust, just vents out with momentum from down below. No duct guiding it from what I can see?
    I went back and zip tied a wire that was in the path to sides were other factory wiring runs.
    This seemed to fix the issue after making everything neat?
    Not sure what caused it but it seems to be from wiring that was in the way? When I run the HV fan with my SG and remove the shock tower assess cover on the passenger side. I can feel hot air coming out. This might be an easy way to get more exhaust venting for anyone that wishes to do that.
    #1 priusCpilot, Oct 7, 2014
  2. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Removed the ?
    edthefox5 likes this.
  3. bisco
    51,851
    twenty questions?:p
  4. priusCpilot
    663
    210
    LA
    I removed the right rear strut access cover. You can feel the heat really come out once you do.
  5. bisco
    51,851
    why do you think your fan is running more than normal?
  6. priusCpilot
    663
    210
    LA
    My fan is no longer running high. I suspect it had something to do with my install of the trailer harness. I went back and cleared any upstrucktion and now its running perfictly. I just left the strut access panal open for better heat dissipation.
  7. Andyprius1
    2,327
    859
    Cool CA
    There is no ducting in that area, if you think it's running hot, slow down, run the AC to cool the battery compartment. The rule is: If you need AC, so does the HV battery.
  8. Andyprius1
    2,327
    859
    Cool CA
    The question is: what's hot. Anything over ambient ?
  9. priusCpilot
    663
    210
    LA
    Once it's going past 106f-118f on the scan gauge it's getting to hot and somthing is wrong. You will hear the fan really come on at that point.
    Andyprius1 likes this.
  10. Andyprius1
    2,327
    859
    Cool CA
    Good. Comment.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Louder than normal? You shouldn't hear that fan at all. Car has no tint and no windshield shade
    And cabin getting super hot? Fan on all the time means your really stressing the battery out
    And shortening its life..
  12. priusCpilot
    663
    210
    LA
    This was only for 1 short drive before I fixed the issue.
  13. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Oh ok.
    You said more than normal.
    Normal is the fan never runs.
    robertmaria likes this.
  14. priusCpilot
    663
    210
    LA
    I updated my post up top to explain better. I didn't read what I wrote last time lol.
  15. robertmaria
    robertmaria Member
    202
    please DELETE this account
    2014 Prius c
    i have my car almost a year,,, i didnt even know there was a fan.
  16. Mendel Leisk
    41,344
    PriusPilot, are you towing a trailer? Or is this for bike transport rack, or?
  17. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    With the Gen III's, it is normal for the battery fan to run in mild to warm weather, especially with a lot of start/stop driving such as in local city driving. The fan speed is generally so slow that it would be difficult to hear. When you get in the 115-120F range the fan speed is getting up in speed mode 4 or 5 range and you can hear it then. The fan speed also varies with vehicle speed so at highway speeds it can be really noticeable.
  18. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    I've only actually heard the fan when something was accidentally blocking the vent. In warm weather, you can put your hand in front of it and feel that it's on low.
  19. Mendel Leisk
    41,344
    I thought our gen 3 fan was never running, never heard it. But since adding XGauges for battery fan speed and battery temp (to ScanGauge), I see it's running a fair amount. Up to fan speed 4 (out of 5 or 6?), when temps around 40~45C. That's highest I've seen.
    jdcollins5 likes this.
  20. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    I'm about to buy an OBD2 bluetooth adapter so I can monitor these types of parameters. My HV battery fan was running at what sounded like max today (it was as hot as 105F on the thermometer, but not unusual in this area and I hadn't notice it running this fast this summer until today).
