are my headlights projector too high? people think i have my high beam on while driving
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by zoeboi954, Dec 14, 2014.
  1. zoeboi954
    zoeboi954 Junior Member
    77
    22
    i have a 2010 prius and it seems like every time i go driving at night somebody flashes me thinking my headlights are on highbeam when they are not. does anybody else have the same issue in their prius
  2. ReDave
    ReDave Member
    82
    25
    Central California, Sierra/Sequoia Foothills
    2019 Prius Prime
    Yes, i'd that happens fairly often
  3. xliderider
    xliderider Senior Member
    8,042
    3,214
    Honolulu, HI
    OEM halogens, or aftermarket HID?
    If halogens, then it might be aimed too high.
    If HID, they might be aimed high, but also could be glare from the squirrel finder cutouts.
    SCH-I535
  4. zoeboi954
    77
    22
    Its oem, straight off the dealership
  5. xliderider
    8,042
    3,214
    Honolulu, HI
    There are adjusting screws behind each headlight assembly for adjusting the aim.
    You can use either a large Philips head screwdriver or an 8mm socket to turn the screw on each side.
    Find a flat level area with a flat wall and adjust the aim when parked 20 to 30 ft away from the wall.
    SCH-I535
