found engine oil leak but not sure where it's from
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by working1, Dec 24, 2014.
  1. working1
    working1 Active Member
    121
    112
    I was changing the ATF fluid for the first time and noticed a film of oil on the backside of the engine right above the oil filter. It appears to be from a sensor, but, not sure what it is. Anyone know or seen this before?
  2. Patrick Wong
    18,200
    6,500
    The third photo seems to show the oil leak is coming from a point at least as high as the exhaust manifold. Who changes the engine oil, and is it possible that person spilled some oil during the process, which dripped down the back side of the engine?
    You can apply some degreaser to the area, wash off with water, and see if the oil stain reappears.
    Or, if you are sure the oil stain is not due to a maintenance error, and assuming your car is still covered under the 5 year/60K mile powertrain warranty, let your local Toyota dealer figure it out.
  3. nedim
    nedim Junior Member
    81
    Redmond, WA
    It could be from one of the sensors there or it could be the seal for the timing chain cover.
  4. working1
    121
    112
    I can rule out oil spilled during an oil change since I've done it myself since new and photo shows a clean area back of the oil cap. I closer look does show the leak is likely above this area. Attached is one photo from the top. Car has over 81K miles so likely not covered by warranty?
  5. Patrick Wong
    18,200
    6,500
    OK, since you would have to pay for the repair yourself I suggest you start by cleaning off the oil stain with engine degreaser and hose down with water. Then see how long it takes for the oil stain to reappear, maybe it will be easier for you to locate its source when you start fresh.
  6. bisco
    51,561
    :(no warranty. are you getting any oil on the ground where you park overnight?
    #6 bisco, Dec 24, 2014
  7. JC91006
    JC91006 Senior Member
    16,738
    8,550
    Does the car use much oil in between changes?
  8. Mendel Leisk
    41,009
  9. working1
    121
    112
    There has not been any noticeable oil loss between changes and no oil dripping on the ground. The area of the leak is not easy to see and the bottom engine panel needs removed to access it. Others could have the same issue and never see it. Plan is to degrease as suggested then use a digital inspection camera to monitor and track down the source.
  10. JC91006
    16,738
    8,550
    No noticeable loss of oil, car is out of warranty, there doesn't seem to be any driving issues....I would just continue on my day.
  11. nedim
    nedim Junior Member
    81
    Redmond, WA
    From the pictures I can tell it is not coming from the engine block or cylinder head or valve cover. I am pretty sure that it is coming from the seal between the timing cover and the block/cylinder head.
    I will attach some photo's so you can see what exactly I mean.
    I doubt it that it is from the two sensors on the timing cover. The bottom one has an o-ring inside the timing cover. The other bigger one on top of it is for the crank position which has a metal gasket.
    That timing cover is sealed with some kind of brown/grey silicone not with a gasket. I was pretty worried when I was planning to close it.
    Oil leak forum member
    johnHRP likes this.
  12. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    Check the area around the timing cover, that may be the leak.
    If that's the case, I would probably turn a blind eye to it. It's not a cheap fix as it requires the engine to come out.
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Is the black connector the crankshaft sensor?
    Leaks at that sensor are not uncommon.
    If timing cover suspect, get a socket wrench
    and check the bolts in that area. See if any
    are egregiously loose.
  14. mbtans
    mbtans Junior Member
    Jacksonville, FL
    I'm at the dealer right now and they discovered oil on the same spots you described - they said mine is a leak from the timing chain cover and the quoted $980 for the work.
    My background: I haven't seen any leaks on my driveway, haven't noticed oil consumption between changes, and had the transmission oil changed about six months ago.
    Working1, what did you do about yours?
  15. JC91006
    16,738
    8,550
    I would refer to post #10
  16. xliderider
    xliderider Senior Member
    8,134
    3,273
    Honolulu, HI
    Are you within your 5 yr/60,000 mile powertrain warranty? If so, it's covered, if it's the timing chain cover seal.
    My dealer quoted $1700 for the job, but I had it done no charge after I reminded them that it is under warranty.
  17. Mendel Leisk
    41,009
    FWIW, there was someone else here with a leak from that cover, the dealership was asking $1700 (US), to reseal it. Ended up no charge, under warranty.
    But yeah, minor leakage out of warranty, I'd just keep an eye on it.
  18. xliderider
    8,134
    3,273
    Honolulu, HI
    Speak of the devil. :whistle:
  19. The Critic
    3,193
    2,330
    CA
    Book time to reseal the timing cover is 14.2 hours, $980 to do it is a screamin' deal. I would take it.
    iPhone ?
  20. prscht
    prscht Junior Member
    37
    Parsippany, NJ
    I had a similar leak on a Prius v wagon that uses the same engine, at around 40K miles. in my case the leak came from the timing chain tensioner cover gasket, which is the diamond-shaped rusty-looking cover secured with two nuts, visible in pictures 1 and 3 of the OP's first comment. in those pictures the cover is partially obscured by the blue tape on the sensor wire.
    This cover is at the same level as the exhaust manifold, which could be why no sign of oil leak existed above this height on the OP's engine, as was in my case. the gasket on my car was replaced under the 60K mile powertrain warranty, and the leak has not returned now at 47K miles.
    #20 prscht, May 22, 2015
