4th generation coming 2015!
Discussion in 'Gen 4 Prius Main Forum' started by edmcohen, Nov 6, 2012.
Thread Status:
Not open for further replies.
  1. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
  2. Tideland Prius
    16,428
    In the worst-case scenario, it might be faster than waiting for a tow! 30 mins is nothing compared to over 24 hours for a tow.
  3. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    Once again, I searched the Internet for anything regarding the 2016 Prius. Several sites show a picture touted (and labeled) to be images of the 2016 Prius. (I tried to attach the picture, but without success).
    What is depicted is a vehicle that closely resembles the current model, except with a sculptured panel beneath the side passenger doors, a sculptured addition beneath the grille that raps around to the front wheel openings, and a slightly different grille. The depiction shows a dark roof, which I assume is a solar panel.
    IF ..... that was in-fact the new 2016, my judgement is that it will take more than a few "tacky" sculptured panels "tacked" on, to hold off the competitors. I wonder if that is what Toyota management has reportedly rejected, and sent the designers, "back to the drawing board?"
  4. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I have no doubt that any pictures currently online are NOT of the 2016 Prius. I have complete confidence that when the 2016 is finally - and officially - revealed, the whole Prius community will shake.
    Think about previous reveals. The 2010 was revealed at the Detroit Auto Show and no one (NO ONE!) had seen any recognizable pictures. Inside and out, under the hood and under the car, there were changes, modifications, and improvements that no one could have imagined. When the v was introduced, we were given hints here on Priuschat, but were not provided with enough information to create a whole concept of what it was. The exact same with the c.
    Each time, these forums were all abuzz with "how'd they do that?", "what, exactly, is that?" and "wow; I didn't see that coming." And those were merely modifications of an existing vehicle. Now we have reason to believe that the 2016 is a nearly complete redesign. I can only assume this means inside and out. New exterior, new interior, new mechanics, new something-we-can't-even-guess. It is for all these reasons that I believe the 2016 will NOT be seen prior to its reveal and when it does come out of hiding we will be breathless.
  5. Ashlem
    Ashlem Senior Member
    754
    502
    WI
    2017 Chevy Volt
    I certainly hope it lives up to its hype. Especially now because of all the new viable competition that has cropped up since the Gen 3 came out.
    I'm Toyota also realizes this, and this is why they're trying to take their time on it. They can't afford to rest on their laurels for long, lest they allow another automaker to steal their thunder, and subsequently, market share, like some of them probably will regarding EV's or at least plug-in hybrids.
    Felt likes this.
  6. scripto
    scripto Junior Member
    55
    Austin, TX
    Three photos, same angle:
    1. 2010 Prius
    2. 2013 Prius mule
    3. 2014 Prius mule
    0903_03_z+2010_toyota_prius+rear_three_quarter_view.jpg toyota-prius-test-mule-rear-three-quarter-4.jpg prius_2014_spy.jpg
    When I first saw the 2013 mule, I thought it was just the current version. Now, I notice small differences: the windows are lower, the side rear corner window is rounded instead of triangular. But the overall shape is pretty identical. I bet this design was rejected for the standard Prius, but might still be used for the plugin version.
    The 2014 mule has significantly less side window area and a lower roofline. Also the rear bumper appears to have been "cut" at several different angles, rather than rounded. Does it remind me of the C-HR concept? Not really, but I can see how a Prius designer might see it as a radical application of the C-HR's "diamond architecture" and sportiness.
    In general, I expect the 2016 Prius to look much more like a Prius than anything else, albeit with some polarizing style quirks.
    Now, does anyone care to wager on whether or not we'll see the real thing at NAIAS in mid-January? Chevy has been teasing the heck out of the Volt for it...
  7. inferno
    inferno Senior Member
    1,072
    405
  8. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    It's very important to set realistic expectations... hence complaints about lack of detail so far.
    For there to be a hype claim, there must already be expectations to meet. What are they?
  9. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    Quasi-quoting the Millennial's Mantra: "...We want it ALL, right NOW..."
  10. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    thread title needs to be changed: 4th Gen Prius is not coming in 2015. It's early 2016, right?
    the 3rd generation 2010 Prius was leaked in video by the Blue Man Crew in December 2008, a month before official reveal. I know you know that.
    Even though 3rd Gen is all-new, it is not radically different from the 2nd Gen.
    Will it be radically different and not be recognizable?
    My interest is to see how well Toyota can appeal to mainstream sedan buyers while still satisfying the space and efficiency 'expectations'.
  11. inferno
    1,072
    405
    Source ? 4th gen still expected fall next year. Supposedly toyota already approved of the production vehicle.
    pip might be released 2016. Then c v 2017
  12. Sabby
    Sabby Active Member
    295
    127
    SoCal
    Lots of discussion regarding the exterior of the Prius. I really hope the interior is upgraded with better materials and a softer touch. I like the current Prius exterior and anticipate some improvements but aerodynamics will still drive the process.
    I hope they retain the flying bridge but improve on the interior electronics, the layout and the materials. A five mpg gain in the Gen 4 would not make me leap to the new one since the benefit is minimal. A nice interior with a refined electronics set up that is phone friendly, with a clear display would make me jump.
  13. scripto
    55
    Austin, TX
    I'm still surprised that they're sticking with the centered gauges, but I take it as a sign that Toyota won't stray too far from a winning formula, promises of exciting changes notwithstanding. I agree that interior needs upgrading to keep up with Ford etc.
  14. Sabby
    Sabby Active Member
    295
    127
    SoCal
    I am traveling and have rented a new Corolla. The interior is a big improvement on my Prius. The electronics and display are still not very good.
  15. inferno
    1,072
    405
    I think 10 mpg gain in the regular prius...let's find out!
  16. jw_teacher
    jw_teacher Junior Member
    87
    MO
    2018 Prius Prime
    Yeah
    Would you forgo aesthetic improvements for a 10 MPG gain? If I could get my hands on a 60+ MPG hybrid I wouldn't care if the interior was improved at all. I know it's wishful thinking with the diminishing returns that Toyota engineers are facing...
  17. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    I know I am bucking the tide here, but I just find it hard to believe that the Prius hatchback, the Prius PIP, and the "v" will all be released in different years. They are , or at least in the past, have been basically the same vehicle. I presume assembled on the same assembly line. I cannot imagine that one vehicle coming down the line will get the new hybrid system, and the next will keep the old.
    Perhaps, the PIP and the "v" will be an entirely different vehicle??? Anyone know if the are assembled on the same line???
  18. 70AARCUDA
    845
    209
    Tucson, AZ
    Simple way to answer that question is to check the 11th-digit of VIN code of PIP and "V" vehicles, and if they have different codes:
    0 = Tsutsumi plant, line #1
    1 = Tsutsumi plant, line #2
    5 = Fugimatsu plant
    then, indeed, they are made on different lines.
    Felt likes this.
  19. Tideland Prius
    16,428
    I think he meant 2016 model year since this thread.
  20. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    I meant 4th Gen Prius coming in calendar year 2016. Last I heard, Prius production was delayed 6 months and deliveries would come in January 2016. Has this changed?
Thread Status:
