FYI - 2012 -2014 Prius Recall
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Eric "v", Jan 6, 2015.
  1. Eric "v"
    Eric "v" Member
    229
    45
    'Vegas, NV, Baby
    2013 Prius v wagon
    Call 1-800-331-4331 for details.
    The Intelligent Power Module inside the inverter module in "certain" Prius models "may be damaged from high operating temperatures".
    If it does occur warning lamps will light and you may be in a "limp home mode".
    The dealer will reprogram you car if it is on the recall list. If you have already had this problem Toyota "will replace the inverter assembly with an new one at no charge".
    51,567
    thanks man! did this just come out today? never heard of it before. i wonder what an 'intelligent power module' is?
  3. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Doesn't affect the Prius Plus or v, only the Gen 3 hatch, different inverter components.
  4. fuzzy1
    10,337
  5. GregP507
    GregP507 Senior Member
    3,002
    481
    Any properly-designed electronic circuit should throttle itself before it overheats, causing damage. Unless of course, some MBA instructed the engineer not to.
