What have you done to your c today?
Discussion in 'Prius c Accessories and Modifications' started by kingnba6, Nov 21, 2013.
  1. kevtan
    kevtan Member
    But I'm from Malaysia bro . I don't think the mirror can survive courier over to USA
  2. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    Damn. i wish there was a USA maker of blue lens for the C
    kevtan likes this.
  3. Crant
    Crant New Member
    2014 Prius c
    Blacked out my emblems, de-badged the back, put on bumper guard, added a back-up camera, put on blue chrome bolts and stem caps and tinted windows this weekend. Check below.
    Flickr: keithlyons228's Photostream
  4. Crant
    Crant New Member
    2014 Prius c
  5. yOsHi LiN
    yOsHi LiN Active Member
    215
    138
    los angeles
    2014 Prius c
    i was bored so i painted my light black
    legoadan likes this.
  6. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
    and added led angel light
  7. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
    and added red devil eyes !!! what u guy think ???
  8. xliderider
    xliderider Senior Member
    8,041
    3,214
    Honolulu, HI
    Did you glue the lens back using clear silicone?
  9. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
  10. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
    yup
  11. Crant
    Crant New Member
    2014 Prius c
    Can you post a link where you got the ring lights?
  12. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
    i got it at a local shop
  13. xliderider
    8,041
    3,214
    Honolulu, HI
    I hope your lens and headlights will be Ok. Silicone adhesive gives off acetic acid (vinegar) when it cures. Hopefully, it will not cause clouding of the headlight lens. :(
  14. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
    i change a white led there but it wasnt really bright. so i was that bored and made this, but it came out good and brite !!! what u think ?
  15. kingnba6
    1,018
    242
    NY
    i did the same thing but just used a simple LED.
    I put a white led but it was too bright so now i have the blue LED.
  16. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    Installed a fortin evo-all remote starter...although I got stuck for a while on trying to take apart the neck of the steering wheel to reach a 7pin steering lock/ignition harness, it was a fairly easy install overall
    #376 SwhitePC, Feb 6, 2015
    legoadan and yOsHi LiN like this.
  17. kingnba6
    1,018
    242
    NY
    very nice! where did you tap into the parking lights?
  18. SwhitePC
    495
    214
    ca
    [/QUOTE]very nice! where did you tap into the parking lights?[/QUOTE]
    main body ecu (30pin) pin#30...I think it was an optional thing, and I think I would've liked my remote start better without parking lights coming on like it's christmas, I'd probably prefer a stealthy no light remote start to the full blown parking lights on and no driver nearby. Maybe I'll disconnect it once I nurse my cuts and wounds...and especially the cold.
    I pretty much pre-prepped the wires for the module the night before, and thought it was going to be fast and easy, since I knew where the OBD II connector and main ECU connector was at, so those two parts were fast/easy; however, I got stuck/confused on where the 7pin ignition/steering lock was located...and it took a few attempts of trying to squeeze under the driver footwell and enduring some cold to finally see that the 7pin connector was behind the plastic driving wheel column (neck) after removing 3 screws and popping off the plastic (top/bottom), the 7pin was just sitting on the top of the wheel neck.
    engine starts with the oem remote 3x simultaneous lock press (so it's range is oem remote range, no extra remote to carry around) and either shuts down when you open the door or 3x simultaneous lock press again
    also the guide was supposed to be for the push-start toyotas...so I don't know if they'll also work for the manuel key toyotas
    #378 SwhitePC, Feb 6, 2015
  19. kingnba6
    1,018
    242
    NY
    Thanks @SwhitePC ! I have the manual key so it might be different. Ill look into it
  20. SwhitePC
    495
    214
    ca
    I'm thinking it's probably the same wiring for the manual key, just that for the programming part, instead of push start to program the module, you'd probably just substitute it with turning the key into acc mode, and program from there. Since I do see some youtube videos with people installing evo-all to their manuel key toyotas, but good luck...have fun and stay safe in the next northeast storm =D
