What is the point of the key included with the Keyfob?
Discussion in 'Gen 3 Prius Main Forum' started by bclinton, Jan 30, 2015.
  1. bclinton
    bclinton Junior Member
    22
    Hi all. Just got my 2nd key from a dealer (used Prius only came with one fob) - it was $375! That is criminal but I had no choice. A locksmith local said he could do it for about $325 but I new the dealer would do it right and I would not have issues with it. That leads me to my question. What is the point to the key part of the fob. I understand it opens the door but that's about it right? If it does not start it what good is it? Was curious about it. I asked the service tech at the dealer and he just shrugged his shoulders :)
  2. Ashlem
    Ashlem Senior Member
    754
    502
    WI
    2017 Chevy Volt
    The key is to open the driver door if your FOB battery dies, so that you can get inside.
    EDIT: And if your fob is dead, you should be able to start your car once inside by holding it near the start button. Then replace the battery asap so you don't have to keep doing that.
  3. bclinton
    22
    Ah, so the key can start the vehicle? Now it makes better sense. I will have to try that. Thanks for the tip!
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Not quite, the Fob can start the vehicle even when the battery fails, but only VERY close.
  5. bclinton
    22
    So if I push the brake and push the start button with the head of the key it should start?
  6. Mike500
    Mike500 Senior Member
    2,593
    767
    Yep, if you place the silver colored Toyota symbol on the button.
  7. bclinton
    22
    Sorry for all the questions but I want to be sure I understand. Do you mean the toyota symbol on the back of the fob? I do not see a symbol on the key itself.
  8. Yakoma
    Yakoma Active Member
    470
    125
    sss
    There's an alternative to the $375 key, but it has a limitation. It doesn't don't do keyless entry.
    prius - ovnisf Keys
    But it's ideal for an emergency key. And it's only $32 plus the cutting charge (~$2 at the hardware store for me).
  9. bclinton
    22
    Thanks. It looks like this is for 04-09 models. I have a 12. I would defiantly get one if it would work on a 12.
  10. Yakoma
    470
    125
    sss
    Yeah.....sorry...missed that fact.
    Send Santiago (OVNI) a private message. He's a pretty innovative guy. He may be working on a solution.
  11. bclinton
    22
    Just sent him an email. Great information! Thanks!
  12. Mike500
    2,593
    767
    Yes.........
  13. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    It is also needed if/when your 12 volt battery goes completely dead........so that you can get inside to open the hood and connect to the "jump points" or to access the battery under the back seat.
    Be sure to test the mechanical key in your new FOB. The dealer may have forgotten to do that part.
  14. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    I'm a little confused by some of the posts here. Lets be sure we're all on the same page.
    The Prius has a rectangular FOB with the key -inside-, correct? I have a Prius "Hatchback", the original version and both the 2007 and 2012 had the above. You remove the key to unlock the door if the SKS doesn't work or the FOB unlock button doesn't work, and if the FOB battery is dead you hold the FOB very close to the "START" button, where it gets enough power to respond to the query from the system about its' serial number, and the car will go to "ready" when you press the start button with your foot on the brake.
    I'm aware Toyota has used slightly different FOBs on different models, but as I haven't seen them I'm assuming some of the posts above may be referring to a different FOB - with protruding key?
    I see Easy Rider 2 has a C, with the battery under the rear seat (I've seen that), but I didn't think it had the boost point in the fuse box?
  15. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    All these posts are correct.
    But really what it boils down to is that IF your fob should fail or be "failing" there is ample reason to want a key to be able to get in the vehicle.
    Once in, closer proximity to sensors should in most cases allow you to start the vehicle. But "getting in" with the key is the first step.
  16. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    The 2012 C did not have a jump point up front, but it was made standard with the 2013s, I believe.
  17. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    The OP bclinton should have said where he is. There are a few places around the country like my shop in Boulder that supply keys/fob/programming for less than 1/2 the price of the dealer. When you ask for help, please list your general location, you might get lucky.
  18. CR94
    CR94 Senior Member
    2,687
    1,165
    Northwestern S.C.
    The whole procedure, including that detail, is explained in your owner's manual.
  19. AzWxGuy
    AzWxGuy Weather Guy
    1,051
    532
    Tucson, AZ
    2021 Prius
    In the interest of a full accounting, there is one other function the metal key provides. It can be used as a flat-blade screw driver to pry open the fob to replace an ailing fob battery. This procedure is also documented in your owner's manual.
  20. Easy Rider 2
    1,584
    258
    Ocala, FL
    Some of the models had a "switchblade" key.
    The underhood boost point is not "IN" the fuse box but nearby.
